Slow bounce to disc
Slow bounce to disc
Dp is terribly slow bouncing to disk on my machine.
Any way to speed it up? It’s nearly real time.
Re: Slow bounce to disc
Just a shot in the dark, but you don’t have anything like a UAD card/satellite or anything that offloads processing to its own DSP? I know, for example, that in the case of UA plugs, any project with plugs like that in it will slow to real-time or just a little bit faster.
No I don’t own uad pluginsJames Steele wrote: ↑Tue Feb 08, 2022 9:00 pm Just a shot in the dark, but you don’t have anything like a UAD card/satellite or anything that offloads processing to its own DSP? I know, for example, that in the case of UA plugs, any project with plugs like that in it will slow to real-time or just a little bit faster.
I have started a TechLink with MOTU about this, latest response was: 'Thanks for the info. We're looking into something which may be related to this.'
Fingers crossed.
Fingers crossed.
Not enough information. Sample rate? Bit depth? How many tracks? Any “look ahead” plugins? Are you rendering VIs? Are you converting from one format to another? Are you bouncing to mp3?Saxplayerz wrote: ↑Tue Feb 08, 2022 6:26 pm Dp is terribly slow bouncing to disk on my machine.
All make a difference, especially bounce to mp3 which can be very slow.
- Kurt Cowling
The three things that slow down a bounce in my experience are:
1. Bounce to mp3, as Mike mentioned
2. Small buffers (yes, large buffer settings bounce faster)
3. Izotope RX plugins like noise reduction and de-reverb.
DP 11.34 , 2021 MacBook Pro M1-Max, 2017 iMac Retina 5K 27-inch, Omnisphere, Trilian, Stylus RMX, EZ Drummer 2, Falcon, Real Guitar, Sample Modeling brass. Audio Modeling reeds, strings, Kontakt 6, Flux Pure Limiter 3, PSP Vintage Warmer, PSP MixPack, PSP StereoPack, PSP Impressor, Altiverb 7, Izotope RX10 Standard, Yamaha S-90ES, Yamaha MOXF-8, Yamaha MX60, Sibelius subscription, Adobe CC and Motion 5.
Hmmmm…. Hadn’t considered buffer settings. Thanks for that tip.Kurt Cowling wrote: ↑Sat Apr 02, 2022 9:27 am The three things that slow down a bounce in my experience are:
I noticed that when I went to 32 bit float, BTD slowed down for me — not unexpected and not an issue on short projects. Long files, though, it will be worth it to increase the buffer first.
The iZotope plugs you mention have ‘look ahead’ functionality that slows things down.
48kmikehalloran wrote: ↑Sat Apr 02, 2022 9:05 amNot enough information. Sample rate? Bit depth? How many tracks? Any “look ahead” plugins? Are you rendering VIs? Are you converting from one format to another? Are you bouncing to mp3?Saxplayerz wrote: ↑Tue Feb 08, 2022 6:26 pm Dp is terribly slow bouncing to disk on my machine.
32 bit float
40
No
No
No
No
I’m not sure if this will help but.
I mix in real time and then bounce the 2 track mix with EQ and compression. But it’s only a 2 track
mix so it goes quickly.
You might try just bouncing 1 track and see if it’s fast or slow and then try 2,3 and so on maybe you could figure out if a certain track is slowing things down.
Just a thought .
Just a thought .
Used 2012 Mac Pro 3.33 6 Core 16g ram 10.8.5 DP 7.24
