DP10 where is "reverse audio"
I've done a search in the 'apply plugins' window. It does not appear.
Re: DP10 where is "reverse audio"
Hmmm... here's a thread that might help:
viewtopic.php?f=1&t=66374
I just tried this and was able to find the plug-in. You first have to select the soundbite you want to reverse, then go to the Audio menu and choose "Apply Plub-in..." Make sure to then select All at the very top of the left pan of the Effects Chooser and search for "Reverse" and it should be there.
Alternatively, I found it by scrolling further down in the left pane and choosing the "MAS" folder and it was there all by itself. (None of the categories within "MAS" seem to contain it. Let me know if you have trouble finding it.
You should DEFINITELY have this plug-in available. I just looked at the package contents of the Digital Performer 11.04 app, and all the standard MAS plugs are contained within the app itself and Reverse is in there.
I have a vague recollection that at some point in the past, (probably before it was moved to plugins as opposed to a menu item)-- there was some weirdness about whether the source track was mono or stereo and having to choose stereo even for a mono track. But that may not have any relevance to this thread.
