problems with stereo outputs from the UVI Workstation
menright
Post by menright »
Hello again, fellow DP people!
This week I switched to Monterey and immediately had problems with MachFive 3, which I learned doesn't work with this new OS. So I opened an older project and began to switch my MachFive tracks to the UVI Workstation. Question for you all: I cannot figure out how to assign a track to a stereo output pair from within the Workstation. When I output a what is clearly a stereo sample to Main Out I hear stereo, but as soon as I assign it to one of the numbered outputs (even when creating a new stereo output bundle for UVI Workstation 2-3, or 4-5, etc.) it becomes mono and is only routed to one side.
What am I doing wrong?
thanks for any help,
mike enright
MacBook Pro 17' 2.66 GHz Intel Core i7, 8 GB, DP9.1, MachFive3, Ethno2, Synthmaster, Waves, UVI, Ableton Live
Re: problems with stereo outputs from the UVI Workstation
Did you create a new Stereo Audio Track under Project or a new stereo Instrument track?
I use UVI a lot and have never seen this issue.
menright
Post by menright »
My original Instrument track was stereo, and I do get stereo from the main outs. It only goes to mono when I give it an output number. I'm pretty sure I'm doing something wrong; I had a similar problem years ago when I was first learning MachFive.
What is your procedure when you assign Workstation to an output pair?
thanks for the help,
mike e
