Update DP from 9.52 to 11, directly?
sayatnova
Post by sayatnova »
Hello Everyone,
I am ready to update my DP 9.52 to 11. Is it OK to do so directly, skipping 10, or, perhaps best to update to 10, then go to 11?
Thank you for any thoughts and suggestions.
http://www.bfdmusic.com
Re: Update DP from 9.52 to 11, directly?
Go for it.
Yup, no problem AFAIA.
I'll be moving from v8.07 -> v11 and don't anticipate any issues.
jim2b
Post by jim2b »
I went from 8.07 to 11 without any problems.
DP 11, High Sierra, Mid 2010 Mac Pro 3.33ghz, 32gb Ram
sayatnova
Post by sayatnova »
How are you all doing with opening older projects created with 9.52 in 11? No issues there?
I am asking because there was a previous thread where a user had issues with opening older project in 11 with track meters behaving correctly, not clear that was properly sussed....: viewtopic.php?f=26&t=69345
sayatnova
Post by sayatnova »
Went ahead and did this last night. So far, everything seems good!...
Good mate.
Theoretically the only issue you should run into is one where you no longer have a plugin installed that's used in an older project.
Obviously, all you do is call up an equivalent into the same slot and tweak from there.
