Can someone complie a complete OSX optimization post?
- Timeline
I went searching for this and so many came up my head began to spin.
If someone out there like Sooshie or James or some of youreal organized types with some spare time could compact these into one concise sticky, I know I would really appreciate it and I think it would be a real nice add for all of us. Maybe I missed it and it's already been done if so let me know.
Thanks guys. Ya'lls da best!
Gary
Gary
I recently looked for the same info, the guys as SOS threw this link->
http://www.thexlab.com/faqs/maintainingmacosx.html
- Timeline
Very helpful. I remember a few other things like diablotin to turn off fonts and shadow killer which I have set up to work at login.
A concise list and directions on all of this would be nice still.
Cheers,
G
Cheers,
G
In a recent issue of MacWorld there was a blurb on a command line method of exiting dashboard.
Does anybody know of an easy way to exit dashboard? I guess I could insert the shell command into a script or automator action, but I've gotten lost trying to program applescript before.
DP 4.61, Powerbook (1.33GHz, 1.25GB RAM, OSX 10.4.4) -> 828MKII
- richardein
I don't think Dashboard on or off helps much - I had it off for a while and noticed nada - but if you go to VersionTracker.com, dollars to donuts there's a script or utility that will do what you want.
Native Instruments also has osx optimization tricks on its website as well.
Richard Einhorn
MacBook Pro 2019, Motu M4, EWQLSO Play Platinum Plus, Ivory, Kontakt 5, Izotope Ozone, Izotope RX, Omnisphere other plug-ins, instruments, etc. that are used less often. StudioLogic SL88 Grand
- alobonzo
You can disable Dashboard With Onyx application easily.
I post you a link that might help
http://emusician.com/mag/emusic_trackin ... index.html
Good luck
Alo
Good luck
Alo
PB G4+Presonus Firestudio+DP
iMac Core2Duo + Cubase4+Toneport UX2
Apple Certified Trainer - Final Cut Pro 6
- Timeline
Thanks alobonzo.alobonzo wrote:You can disable Dashboard With Onyx application easily.
Good luck
Alo
Found the link here for Onyx:
http://mac.softpedia.com/progDownload/O ... -7005.html
http://www.boostware.com/os/mac.html
In the same MacWorld article where they described how to turn off dashboard, it stated that each dashboard widget occupies about 5MB of RAM. You can check the actual amount with the Activity Monitor.richardein wrote:I don't think Dashboard on or off helps much
I don't recall if they stated how much RAM just the dashboard application sans widgets takes up.
If you're tweaking your system by turning off things like fonts and shadows, it seems to me that turning off dashboard would be a no brainer.
Thanks for the links to Onyx.
