Tidwells@aol.com wrote: ↑Wed Nov 17, 2021 11:36 am
Hello again!
So if I replace the SSD in my mid 2012 Mac Mini with a large new one, what is now the best way to clone the old drive to the new? I used to use Carbon Copy Cloner and clone the drive before swapping it out. Seems like Iast time I checked, CCC is no longer free. I like to clone the existing drive so I can easily stick with the existing Mac OS version and everything just seems to work without new headaches. Any recommendations for free cloning software? Or should I just go ahead and use CCC?
Doug
Cloning is part of Disk Utility. Cloneware are APIs for this. Although part of the MacOS, there are reasons why Apple never ever ever ever
ever recommends cloning for OS installs since OS 10.4 Tiger. I agree 100%.
Not only is it unnecessary but with some drive swaps, it causes problems. A 2012 Mini isn't likely to experience these but I still agree with Apple. There's a correct way.
That said, it's ok to make a bootable clone to use as an installer but don't use the new drive to do it. If you have one, you can skip the step 2 below.
1) Download a copy of the MacOS you want to install. If you have a bootable external drive, put it on the desktop of that drive. Othersise,
2) Make an installer on a USB thumb drive. I have instructions if you need it.
3) Install your new SSD into your Mini. While in there, replace the BR2032 battery — a common CR2032 medical battery works fine (if you live in extreme heat or cold, get a BR2032 from Amazon). You'll notice most of these directions are same as replacing the drive.
https://www.ifixit.com/Guide/Mac+mini+L ... ment/11725
4) Boot from your thumb drive or external disk. Open Disk Utility from the Installer.
5) Using Disk Utility, format the new SSD as APFS unless installing Sierra or earlier.
6) Quit Disk Utility, install the MacOS. When done, your Mini will boot from the SSD into Migration Assistant. Select your language, give your Mini an Admin password and verify your Apple Support and iCloud accounts.
7) It will ask you to bring in your data, settings and apps from another Mac, drive or Time Machine. Let it bring your data over. When done, it will reboot and want to do some more housekeeping.
Next time Time Machine runs, it will ask if you want to inherit the old backup. Normally, the answer is Yes.
9) When done, enable TRIM by opening Terminal and entering the following command:
sudo trimforce enable <Enter or Return key> Enter your Admin password when asked. The OS will ask you to verify you really want to do this. You do.
Normally, you should be good. There are situations where you may have to reset the clock before a new OS install. Replacing the battery can sometimes trigger this if you were too slow. Read this and have the directions handy just in case.
https://bensmann.no/changing-system-dat ... -recovery/
If installing a MacOS older than Catalina, do not enter today's date—instead set to a date within three years of the OS release date. The clock will reset correctly the first time you connect to the internet.
