Backblaze and Data Streaming Rate
primeevolutionary
Post by primeevolutionary »
I purchased a subscription to Backblaze and started backing up on September 5th. I received a notice on September 15th that I've exceed my plan's allowable data GBs for the month. I can see that I racked up a quick 1,278 GB uploading in that ten days.
Is this just the initial data upload and once I am uploaded, it will go back down to normal usage as it only uploads changes afterwards, or, do I need to increase my monthly data?
OS X 14.7
DP11.32
Stage-B16
2 828 mk1s
MTPAV USB
Re: Backblaze and Data Streaming Rate
This is temporary, until all drives are backed up.
It seems that if you re-name a drive, it will not be recognized, so will back up again (unless the data is already backed up - my understanding is BackBlaze automatically does not back up duplicates, just links to them. I may not be accurate here. More info on the BackBlaze website.)
primeevolutionary
Thank you, HCM!
OS X 14.7
DP11.32
Stage-B16
2 828 mk1s
MTPAV USB
