Woohoo!HCMarkus wrote:The door has been opened.
Thank you, Sir Markus.
I recently (last week) purchased a flashed Alpine Ridge Thunderbolt 3 PCIe card from Superchief9 on ebay, and I can confirm that it works -- plug & play -- on my 2010 5,1 running Mojave.
Hi Greg -- my expertise on this stuff only goes so far, but... the Alpine Ridge card I have is also a rev 2.0, so I don't think it's "earlier", it's just not as powerful as the Titan Ridge. And I think any Gigabyte card will need to be flashed by someone -- seller or end user -- before it's useable in our old Mac Pros, right?greg328 wrote: ↑Wed Sep 15, 2021 11:04 am tremo--I appreciate your reply. It seems you are using an earlier card--not the one I posted. The card I linked to, Titan Ridge 2.0, apparently is flashed for use in Mac OS right out of the box. You had your earlier card flashed by the seller, and you've got it working with the custom boot, is that correct? That's great!
I just want to know if the Titan Ridge 2.0 card I linked to above, that actual card---if anybody has experience with it..
TY,
Greg
Right, but the seller has flashed the card, as he says: "Titan Ridge PCIe Card In Original Box (only opened to flash)".
Yes, that's right, Greg. After a normal startup, System Report (under Thunderbolt) shows the TB3 card and the UA Satellite looking normal. But the UAD Control Panel gives a "No device found" or "Not connected" error until you do that additional restart.greg328 wrote: ↑Wed Sep 15, 2021 2:56 pm Yes I see where the seller has opened to flash, but he’s advertising it as able to cold boot into macOS. Is that what you’re doing with your flash card as well? Apparently you’re having to reboot at the start up screen after you turn on your UA device, is this correct?
Yeah, I am stuck at 10.14.6, and on my login screen (after a restart), there are three buttons at the bottom of the screen: Sleep / Restart / Shut Down. You click that Restart button for the second boot.
