monitoring issues 896HD 828mkII
Independent since 1995
Post by Independent since 1995 »
First off my set up.
Powerbook (Titanium) OSX 10.3.9
896HD
828mkII
all connected thru firewire
DP 4.6
2 issues
1) How can I monitor all of my analog inputs (896HD and 828mkII) from the HD XLR monitor outputs. I only here the HD inputs and not the mkII. My I/O's are set properly in the DP software. I am receiving all the inputs just fine (Im using 16 of them right now 8 from each interface) and I am able to view them in the audio monitor window perfectly and track them. I shift clicked both the HD and mkII in the Configure Hardware window. I have the HD as master and the mkII clocked to the HD. I have the Sample Rate set to 44.1 and the Host buffer is set to 2 with work priority set High. Again, I only hear the HD inputs and not the mkII, I need to hear both thru my HD XLR monitors outputs.
2) When I monitor my outputs (in the same settings above) I get click pops and what sounds like a gate effect. I have to push the volume then it seems to release with a 10db boost uncontrolled.
I appreciate an advice or comments thank you.
:evil: :cry: :evil: :cry: :evil: :cry: :evil: :cry: :evil: :cry:
Last edited by Independent since 1995 on Mon Feb 13, 2006 6:10 am, edited 2 times in total.
Mark Porter
chessboard.studios
Downriver/Detroit Michigan
Pappy725
Post by Pappy725 »
With a set up like that, you should be getting a lot more than 14 inputs. There are 10 analog on the 828mkII, plus the 8 ADAT and the 2 spdif. Are you using the CueMix application to check the monitoring situation? It should have come with the 828. Hope some of this helps.
Stephen
MacBook Pro (Retina, 15-inch, Early 2013)
2.4 GHz Intel Core i7, 8GB RAM, OS High Sierra 10.13.2, DP8.07, 256GB SSD
828mkII, 8Pre, Alesis M1 Active Mk2, Ext. FW drives, Yamaha fretless bass, Kay upright bass, Wechter acoustic/electric, trombone, baritone and a proclivity for polka music. (With sufficient quantities of beer) and I play country music.
