No need to create from scratch. MOTU highly recommends using new templates in DP 10 (or 9.52 or 11 as it applies to you) — fortunately, this is really easy.kinnylandrum wrote: ↑Wed May 09, 2018 7:30 ambayswater wrote:Did this start with a template? If so, maybe try a template created in 9.5.2.
Interesting idea. I'll try that. You mean I have to create a new template from scratch, not just copy an old one?
Open your template.
Fix any issues include updating any plugins (ex: shows RX7 but you now have RX8 etc.)
If you want to add, delete or rename tracks, aux's etc., now's the time to do that, too.
When done, use the Save As menu to create your DP 10 or 11 template. I recommend renaming it, too, such as the old template name with 2021 added to the name.
You're done. Takes 30 seconds to a few minutes depending on the number of changes made (if any).
If the new one works as expected, you can now go in and delete the old template. The path is different depending on Mac or Win.
