The VEP plug in is not Apple Silicon compatible yet, it has to be run in Rosetta. This is on VSL not MOTU. Logic supposedly can run Rosetta plug ins in the M1 version, but nobody recommends doing it, i.e. it runs badly.gulliverity wrote: ↑Mon Jul 12, 2021 6:59 pm I must be the only one here on an M1 Mac using VSL virtual instruments. Thank God I ran the 30-day demo before plunking down cash! DP11 will not recognise Vienna Symphony's MAS nor VST plug-ins. You will get an error message the first time you run a project which contained them indicating a long list of the instances which cannot be located. The only option is to re-assign them — one by one — to Vienna's AU plug-in.
If you revert to DP10 and open that same project, you'll get a bit of a scare to receive the same warning, but fortunately in this case DP only disabled the MAS plug-in. Re-enabling brings joy back to the world.
NOTE: If one is a glutton for punishment, one can force DP11 to run in Rosetta mode ("Get Info" in the Finder) and it will recognise the MAS/VST plug-ins. The Map Articulation only seems to work with Synchron Player using the VST plug-in which is another hassle if you've been using the MAS version all this while.
If I had paid MOTU $195 for their advertised compatibility with Apple Silicon...after the wait from November 20th without a peep from them... I would not want to be on the receiving end of THAT phone call.
DP11 is here!
Re: DP11 is here!
Re: DP11 is here!
I just saw a nice little DP11 announcement article over on CDM. It mentioned a little thing I didn't catch before now.
"Also, here’s a tiny feature with huge implications, by user demand: you can strip silence by dB threshold and not just percent. That solves a ton of workflows in a range of use cases."
That's nice to see. It's how it always should have been, but better late than never. Nice!
Re: DP11 is here!
Cool! Thanks for pointing that out, Stubbsonic.
DP 10.13, OS 13.6, iMac Pro (2017) 3.2 GHz 8-Core, 32 GB RAM, MOTU M4
- terrybritton
- Primary DAW OS: Windows
Re: DP11 is here!
Geesh! Weren't we just raging on about that a few years ago??? Fixed already??? What influencers we are.stubbsonic wrote: ↑Tue Jul 13, 2021 11:13 am I just saw a nice little DP11 announcement article over on CDM. It mentioned a little thing I didn't catch before now.
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
Re: DP11 is here!
Hmm. What I recall clamoring for was an indicator on the waveform that showed what the the Strip Silence threshold value was referring to (as some might remember StudioVision had). I'm not sure if dB will be much more useful than %.terrybritton wrote: ↑Tue Jul 13, 2021 12:11 pmGeesh! Weren't we just raging on about that a few years ago??? Fixed already??? What influencers we are.stubbsonic wrote: ↑Tue Jul 13, 2021 11:13 am I just saw a nice little DP11 announcement article over on CDM. It mentioned a little thing I didn't catch before now.
Anyone spotted any other undocumented DP11 changes?
Re: DP11 is here!
For me, dB is 100dB more useful than %.
Re: DP11 is here!
... which is 90% better in your case, Stubbsy; I'm almost 100% sure of it.
Personally, I'd love a graphic indicator that updates as one adjusts the threshold.
Realtime splitting of the soundbites according to threshold-parameter adjustments as a further indicator would be awesome too IMHO.
- Timeline
Re: DP11 is here!
I love the fader stretch idea but wonder if resolution follows.
Re: DP11 is here!
I didn't think of that. I'll have to check. Should be testable.
Re: DP11 is here!
This.
Can't wait to hear results.
I think I'm going to get this update sooner than I thought...
Re: DP11 is here!
Started demo. First thing I checked is does it still hang-up crash on bounce to disk. It does.
Krakadon
aka Dave Williams
Rock, metal, Camas, WA
* 15" Mid-2019 MBP 2.4 GHz 8-core i9, 32GB RAM, Ventura 13.6.5. TB: UA Apollo QuadFW w/TB card, Satellite OctoTB2 & OctoTB3, PreSonus Quantum 4848 TB2; USB 2.0: Ext USB3 drives, Fractal Audio Axe-Fx III , Revv Generator 120 MK3; USB 3.0: Stream Deck XL, M Audio Oxygen 49, Akai MPD218, Console One Mk3, SSL UC1, X-Touch U; HDMI: 34" 16:9 & 32" 2K Monitors
* DP 11.31
aka Dave Williams
* DP 11.31
- tommymandel
Re: DP11 is here!
I agree (with everybody) but... with DP10 running very well here, and me not needing MPE support and having real concerns about some of my older third party plug-ins dying, I am still deciding whether I need DP11. I would have to take my 5,1 up to 10.13 from 10.12, (or maybe to 10.14 to match my 2015 laptop.) But that's as high as i want to go, Apple. Thanks for, as bayswater put it so well, denying us the ability to: pick the software we want to run, then look for the hardware and OS that runs it -- not buy a computer because it's new and then wonder why the software we want doesn't run on it.bayswater wrote: ↑Wed Jul 07, 2021 4:49 pm ... it's not the cost, but updates for the sake of updates ... if you're sticking with DP 10 why does it have to be run in OS 11? What's wrong with 10.14?
Maybe I'm out of step with the world here, but it seems to me we should pick the software we want to run, then look for the hardware and OS that runs it -- not buy a computer because it's new and then wonder why the software we want doesn't run on it. There will alway be a few people who are forced to buy a new computer that won't run software that's more than six weeks old but that's life.
Maybe we need more complaints to Apple about why they'd make a computer that abandons existing software?
DP 11.03 12core(5,1): 64GB/10.13.6, two 24i/o's, two 2408mk3's, 4pre, MicroLite-- MBP 2015 16GB/ 2TB 'Blade SSD 10.14.4, Mainstage, Numa C2x, ReMOTE SL -- SupDrmr, 32 Lives, SampleTron,Keyscape,MTronPro,RolCloud,Icarus,Dune,OB-E; Clearmountain Domain,Soundtoys,AdrenaLinnSync, LinnSequencers,Tempest, Montage, JU80, Sledge, Prophet-X, OB-6 V-Synth, s70xs, D-50, TS-10, JD800, Karma, Pa-1x B3, Wurly, Mason Hamlin.
Re: DP11 is here!
Just to be clear, as I see some confusion here and elsewhere, that DP 11 runs on Intel machines just fine (at least for me). I get the impresson that some people think they need to upgrade to an M1 Mac to run DP 11. Not so.
828x MacOS 13.6.7 M1 Studio Max 1TB 64G DP11.32
- tommymandel
Re: DP11 is here!
thanks, cuttime...yes, my post sounded like I thought that, sorry, didn't mean to.
- toodamnhip
Re: DP11 is here!
I still havent seen any sign of a big fix list, anyone seen one? Also, I applaud MOTU for improving articulation mapping. But does anyone here wish for a fader bank dedicated to continuous controllers? For me, dealing with controller data in VIs will never be convenient until they are translated into a fader bank so one can touch, trim and do all the automation necessary to comfortable edit CC data. That would be a fantatsic "next project" for MOTU! I never hear others speak of such a feature, but it seems to make so much sense.
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
64 GB 1866 MHz DDR3
Mojave
DP 10.13
