Buzz in Monitors cuased by Apple Display?!
dubaifox
Post by dubaifox »
I have been getting an annoying hum in my Mackie monitors recently, and after much trial and error, found that it seems to be caused by my 19" Apple Flat Panel Display.
The instant the monitor goes to sleep the buzzing dis-appears. Re-appears when it comes back on.
Any idea why this is happening?
DP5.13, 2xMacPro 2.66, OS 10.4.8,01v96
3xVisionDaw PC, Pro Tools 7.3, Reason 3.0 RMX,Trilogy, Atmosphere, Platinum, RA,Komplete
Apogee Rosetta 200
www.musichf.com
Astia
Post by Astia »
Hi Dubaifox.
I have an Apple Flat Panel right next to Mackie speakers and have no hum with the monitor on or sleeping. How ever I had problems with a poor rca-cable(from console to nearfield spkr amp) which the monitor had a strong effect. Replacing the poor cable with a "pro rca cable" removed the noise.
Do You have any cables running near the Flat Panel?
G5 2x2.75GHz, 4G RAM, OSX 10.4.5, DP4.61, Mach5, 2408mkIII, 1296, ExpressXT, AutoTune3, Waves Renaissance, PowerCore mkII, UAD-1, 2-1176, Distressor, LA2A, TLAudio VTC, Mackie DXB200 w/3xUAD-1..
Rokrok & siihen ralliin!!!
a_real_mf
Post by a_real_mf »
i too had this problem....for me it was noise when i moved the mouse or when scrolling, ie when anything changed on the screen. turned out it was an external firewire hard drive!!! the manufacturer said it was not possible, but when removed from the mac the noise went away.....try rmoving external drives, and see what happens
mf
a real "mf" production
http://www.arealmf.com
TOD
Post by TOD »
Make sure all power cords are far away from the monitor and speakers. That fixed my buzz.
DP 5.13 dual G5 2.7 synced to dual 1.42 via SMPTE, Muse Receptor (filled with Stylus RMX, Trilogy, Atmosphere, Elektrik piano, Disco DSP), OSX.410, Ableton LIVE, Apogee Big Ben, Apogee mini DAC, MachV, Symphonic, Ethno, M-Tron, Mx-4,Latigo, Jupiter Vi, iDrum, Microtonic, Kontakt3, Bassline, Bassline Pro, Ultra Focus, Novation Basstation, Novation Drum Station, Nord Lead2, JD-990, EMU Proteus, Orbit 2, MicroKorg, UAD, Poco, Altiverb, VW2, Waves, Ozone, to name a few :)
