Routing Audio 828ES M1 Mini
DAWdler
Post by DAWdler »
Hello all,
I thought I would try running DP on a M1 Mini with a 828ES. I am failing miserably. I'm trying AVB though ethernet. I can access the 828 though Pro Audio and route the signal from analog inputs to computer inputs, I see signal on the 828 screen but no audio in DP. DP shows the 828 in setup and Bundles, but nothing in Audio Monitor or Meter Bridge. I'm set to the 828 in Sound Preference Pane. I'm baffled. Probably something either ridiculously simple or a Big Sur incompatibility. But if anyone has gotten similar setup working, let me in on the process please.
Mac Studio, 828ES
MacOS 15.5 DP11.34
Bunch of noise making things
Re: Routing Audio 828ES M1 Mini
DP isn't Big Sur ready, (or is it?) Welcome to the bleeding edge!
You will undoubtedly love your M1 Mac someday but there may be a few days of frustration between now and then. (I will surely be getting one once we are further into the transition to Apple Silicon.)
HC Markus
https://rbohemia.com
PhireAlly
Post by PhireAlly »
DAWdler wrote: Mon Feb 15, 2021 4:38 pm Hello all,
Hey DAWdler,
I've gotten DP9.52 to work, along with my MOTU 1248 via AVB on my M1 MacMini.
My connection is simple .... CAT 6 Ethernet cable from the Ethernet port on the Mac Mini to the Ethernet port on the MOTU 1248 ... done !!
No USB or Thunderbolt cables connected.
I had to sort out some clocking issues but after a night of troubleshooting... it turned out that Studio One v5 was sensitive to buffer sizes over 1024 on the AVB stream but DP 9.52 and Logic Pro didn't exhibit any such issue.
I'll link a YouTube video below from a gentleman that did some videos on AVB for Presonus, It helped me a lot.
I also read the MOTU 1248 user manual, also helpful.
Few things to note...
(1) Do NOT check your 828ES radio button in the Audio MIDI Setup > Network Device Browser window.
It's going to create another "entity" that will cause problems.
(2) In Network Prefereces, select Ethernet then choose Advance (Lower right corner)
Goto the Hardware tab and change the "Configure" dropdown from Automatically to Manually.
This prevents another "entity" from being created.
(3) Locate the Apple "AVB Audio Configuration App" and drag it to your dock.
It's can be found here ...
Macintosh HD > System > Library > Core Services > AVB Audio Configuration app.
This is the app that the Presonus Universal Control and the Terminal command from the video below will launch.
A few more things to note ...
(1) MOTU AVB Audio Interfaces only support 8 channel streams.
(2) Media clock Input stream is not necessary for MOTU AVB Audio Interfaces. Leave it at its default setting.
(3) Choose (IEC-61883-6 AMB-24 48kHz 8 data blocks non-blocking 8 MBLA) ... for all your input and output Stream Formats.
Follow the video and you should be ok.
https://www.youtube.com/watch?v=v-Rkl7Th_1g
Hope this helps,
PhireAlly
MacMini M1, 8-Core @ 3.2GHz, 16GB Ram, MacOS 14.7.5 (Sonoma)
MOTU 1248 - MOTU 16A (2014)- MOTU 8A - Antelope Audio Zen Q - Arturia AudioFuse (Rev 1)- UA Apollo Solo
MOTU DP 11.3.4 - Studio One Pro 6.6.4 - Logic Pro 11 - Nuendo 14
Acustica - Antares - Apogee - Arturia - Blue Cat - Boz Digital - Celemony - Eventide - FabFilter - Flux
HorNet - IK - iZotope - Kazrog - McDSP - Melda - Nomad Factory
Plugin Alliance - Softube - Soundtoys - Tokyo Dawn - UAD-2_TB2 & PCIe
Valhalla - Waves v14
DAWdler
Post by DAWdler »
Thanks for that! I won’t have a chance to look at my setup until the weekend, but it appears I missed something in setting up AVB. DP10 inputs show an 828 but it doesn’t seem to correspond to the 828 in the Pro Audio app. I’m guessing I have the “another “entity”” problem.
Mac Studio, 828ES
MacOS 15.5 DP11.34
