Hello all
I am setting up a small music studio for vocal instruction. I have found over the past few years that a good quality recording of a lesson makes an invaluable tool for practicing with. To that end I have been using a small portable rig to record lessons (see my sig below for details). Now that I will be setting up my own studio I have decided that an in house recording system would be ideal.
Any recommendations would be greatly appreciated.
The recording environment is a room about 15 feet x 22 feet. One upright Yamaha piano, and a Yamaha Clavinova Keyboard. The room needs to be mic'ed for area recording so that all that occurs in the room is picked up. The students will not be standing in front of a microphone.
Generally a flat EQ response is most desired as a lot of instruction involves classical music. (microphones, pre-amps ??)
I would like to be able to send the audio signal to several different types of recording gear, (ie. simple cassette deck, a wave recorder, mini-disc, DAW etc.) so flexibility in routing is needed. (mixer ??)
Although money is a consideration I would prefer decent quality equipment so that I don't have to worry about to much noise floor.
Any other comments or suggestions, just in case I am missing something in the signal chain.
Thanks in advance
Tera
Vocal Studies Studio, equipment suggestions?
Powerbook G4 1Ghz, 768M Ram, GEM RPG800. For vocal lesson recording: Behringer MXB1002 mixer, 2 x Behringer ECM 8000 omni mics, 2 x Behringer C2 cardiod mics, Edirol R-1. For recital recording: Alesis FireWire Multimix 16, 2 x Studio Projects C3 and an AT835b for vocal focus.
If the flatest omni mic is your objective buy the Earthworks that fits your budget. As for a preamp, you are talking some serious money for the likes of a True, Millenium, or Manley. I am sure there are others, but these color the sound very little. All in all, I would think $2K-$3K to get what you are saying you want.
Mac G5 Dual Core w/ OS X Tiger, DP 4.61, MOTU Traveler, Apogee Big Ben, TC PowerCore, Tranzport, Glyph External HD, decent pres and outboard fx.
I second the Earthworks omni's. For about a grand you can get two Grace Design 101's. Yummy!epidot68 wrote:If the flatest omni mic is your objective buy the Earthworks that fits your budget. As for a preamp, you are talking some serious money for the likes of a True, Millenium, or Manley. I am sure there are others, but these color the sound very little. All in all, I would think $2K-$3K to get what you are saying you want.
MAC PRO 2x2.26 / OSX 10.7.2 & 6 GB RAM., POWERMAC G5 2x2. / OSX 10.5.9 & 4 GB RAM., MAC BOOK 2.0 / OSX 10.7.2 & 2GB RAM.,DP 7.24, Logic Pro, Motu 896mk3, Lynx Aurora 8, Motu Ultralite Mk3, UAD-2 6.1.0, Mackie Onyx 800R, V-Drums.
- BradLyons
- Primary DAW OS: Windows
There are many options available to do this but as pointed out, the quality you want will determine the price-point. While Earthworks mics are wonderful, you're recording lessons...NOT a professional CD so IMHO, you don't need to go crazy here price-wise. While the R1 is a cool device, I think in your case you need a multi-channel setup. Being that you want to record a CD, Cassette, etc all at once... I would suggest a mixer, perhaps the Mackie Onyx Series with the Firewire option. This would allow multi-channel recording direct to the computer, but also to buss audio out to a stand alone CD recorder and Tape Recorder as well as playback on a moments notice. The pres are good, certainly not on the level of the others mentioned but again for the application....PERFECTLY fine!
As far as microphones, I'd suggest something like a Rode NT4 on the piano (stereo microphone) and for the room...possibly the same. Now if you're wanting "studio quality" sound and aren't afraid to shell it out, then yes going with some QTC30's or the likes would make sense. I've designed numerous studio packages and rehearsal setups, I don't think you should buy the high-end gear for this...but don't buy junk, either.
Thank you,
Brad Lyons
db AUDIO & VIDEO
-Systems Advisor, CTS
Brad Lyons
db AUDIO & VIDEO
