Strange issue: distortion on soft synth on headphones but not monitors
Hi - I noticed a strange issue while recording last night in DP. I added an instrument track with Arturia Pigments 2 on it and noticed a cracking static noise on each preset when monitoring through headphones. When I listened to the synth on monitors, the static is not audible. The signal sounds normal. Further, I don’t hear any distortion when playing hardware keys in either headphones or monitors. Just when playing the plug-in. I’m using an 828es. Is there something I am overlooking in routing the plug-in synth? I’m running Catalina, latest versions of Arturia/MOTU software. Thought it could be a sample rate conflict but I would expect to hear the static on the monitors too. Thanks
- Gravity Jim
Re: Strange issue: distortion on soft synth on headphones but not monitors
Have you checked your gain staging on the offending channel(s)?
Jim Bordner
The next thing I'd check is buffer size.Gravity Jim wrote: ↑Mon Dec 28, 2020 12:29 pm Have you checked your gain staging on the offending channel(s)?
