I set up a DP sequence and tailored some bundle settings to external MOTU 2408 mk3.
When I re-open the sequence now, the bespoke bundle output names show next to track items, but the audio does not connect. Why has the bundle stopped implementing?
Is there a way to make DP9 re-latch to the bundle settings that it has remembered, but stopped implementing?
Did you use the Load command or imported the tracks from another session?
If so, this happens very often, and it's extremely annoying. There's a way to avoid it, but it requires a very narrow and impractical set of conditions.
All you may need to do to fix it is to put the tiles by double-clicking in the faulty bundles in the Bundles window.
--------------------------- "In physics the truth is rarely perfectly clear, and that is certainly universally the case in human affairs. Hence, what is not surrounded by uncertainty cannot be the truth." ― Richard Feynman
