Editing middev and midnam files in OSX 10.15.7 (Catalina)
- GDFourcade
Wich program is available to edit the MIDI patch names of my external MIDI synths in OSX 10.15.7 (Catalina)?
I'm using DP 10.13 and the middev and midnam files are located in /Library/Audio/MIDI Devices/MOTU/Kurzweil.
CherryPicker was my option several years ago...
Any suggestion?
TIA
Any suggestion?
TIA
Re: Editing middev and midnam files in OSX 10.15.7 (Catalina
AFAIK we've no choice but to use TextEdit (that's all I have 'cause it's "built-in").
It's a PITA but it can "easily" be done. Not complicated, just a chore. Just be sure to save as "Unicode (UTF-8)" format when you're done.
You'd be best off using a text editor with XML support (as these files are XML files), i.e. not textedit. I still use TextMate https://macromates.com/ on OS X 10.14
TextEdit still works 'though Rich, as long as you save in the "Unicode (UTF-8)" format, as I suggested.
How about BBEdit? It still has a free mode and works well with a lot of formats. It displays MIDNAM and MIDDEV files clearly.
Ahh.. yeah I've heard of that one, Stoivo.
I didn't say TextEdit didn't work. It remains a poor choice vs the many editors that can assist with syntax-highlighting and correct formatting of these files. TextMate (and others) will highlight all the tags in different colors, assist with tag matching (so you don't create an invalid file), will let you expand/collapse the different sections of the file etc. There's no comparison - some (TextMate et al) are tools that can help you and one (TextEdit) is a tool that doesn't help at all. In the image below the top editor is TextEdit and the bottom one is TextMate. Note the colored syntax highlighting and the expand/collapse tools on the left side.monkey man wrote:TextEdit still works 'though Rich, as long as you save in the "Unicode (UTF-8)" format, as I suggested.
https://drive.google.com/file/d/1Gn9xu7 ... sp=sharing
Sorry mate; it sounded to me like you were saying it wouldn't work:
The solution I offered to the OP also took into account what he / she would've already had software-wise, and as I said, "that's all I have 'cause it's built-in".
Thanks for the info, mate.
I looked at the image (thanks), and was actually disappointed 'cause I expected things to look much-simpler (I don't know how 'though - above my pay grade). So for me anyway, TextEdit doesn't seem complicated at all and I've edited dozens of .midnam and .middev files over the years using it.richhickey wrote:You'd be best off using a text editor with XML support (as these files are XML files), i.e. not textedit.
Re: Editing middev and midnam files in OSX 10.15.7 (Catalina)
Perhaps there's some way to run Cherry Picker on a different computer and then copy over the generated folder and file to the newer computer. Certain things might have to be tweaked. I don't know... haven't had time to mess with it.
- gseibert
I just recently did as James suggested. I created a Kurzweil PC3 MIDMAN and modified MIDDEV file on my old Mac Pro 3,1 running 10.11.6 using Cherrypicker. I transferred the files over to my 2020 27" iMAC running the latest Catalina. The files worked great. I'm on DP 10.13.
2020 iMac 10 core 32 g ram, Catalina, DP11.04, UA Apollo X4, MTP/av usb, Komplete Ultimate 13,Albion One, BBCSO Core, TX81Z, SPX90, Digitech Studio Quad v2, Tascam DA20 mkII, Alesis ADAT, Roland s750, Mackie line mixer, Korg Z1, Roland A80, DX7, Kurzweil K2500X, Kurzweil K2000R, Kurzweil PC3, Korg 168rc Event 20/20 bas, Mini-Moog, EMS Synthi aks
