YES!labman wrote:VEP bug has been fixed!!! Whew. Color me excited.
DP 10.13
Re: DP 10.13
Re: DP 10.13
You are very welcome, sir.HCMarkus wrote:I'm sure this is exactly why client and I experienced a major mix F-up last night and I went to bed at 3AM this morning.
Thank you so much for that Phil.
The workaround, BTW, if you decide to use VCAs is to make your VCA adjustment then turn off groping, set VCA to zero and turn grouping back on. If you're automating the VCA fader, then you're out of luck.
I've decided to give up on VCAs until MOTU gets their poop in a group on this. I just route a group to an aux channel if I need to automate the stem.
Re: DP 10.13
“Poop in a group?
Poop in some soup!
Poop in a hoop,
Poop in a boot.
I don’t give a poop hoot.”
From “Brown Eggs and Ham”
Poop in some soup!
Poop in a hoop,
Poop in a boot.
Re: DP 10.13
MIDI Life Crisis wrote:“Poop in a group?
Poop in some soup!
Poop in a hoop,
Poop in a boot.
Re: DP 10.13
I'm sure this came up before but I missed it. The application bundle contains the MAS plugins, but these are still in the usual Library folders. The version numbers are the same although the build numbers and icons are different, the and the file sizes are slightly different. Does this mean we can delete the MAS plugins in the Library folders?
Re: DP 10.13
Updated to .13 yesterday and ran a big mix session (created in .11) all night without a crash.
Great news: was able to successfully LOAD a DP5 session including all sound files into my template using DP10.13. This was not possible in DP10.11. The timely arrival of .13 has saved me a bunch of tedious hours merging, importing and organizing files for a client and, by extension, saved that client a bunch of money.
Re: DP 10.13
Thanks for posting this. Where in the world did you find it? I've looked for two days, looked at all the help files, and I still can't find it...dix wrote:Link to the 10.13 Read Me https://www.freqsound.com/motuuserfiles/DP1013.pdfcuttime wrote:Whoa. I'm not in a position to DL yet. Is there a read.me or changelog anywhere?
Re: DP 10.13
I found it in the installer. Not used to looking for it there.cuttime wrote:Thanks for posting this. Where in the world did you find it? I've looked for two days, looked at all the help files, and I still can't find it...dix wrote:Link to the 10.13 Read Me https://www.freqsound.com/motuuserfiles/DP1013.pdfcuttime wrote:Whoa. I'm not in a position to DL yet. Is there a read.me or changelog anywhere?
Re: DP 10.13
"Added shortcuts for scaling from 100% to 200% in 25% increments to the scaling window menu."
If you want to add shortcuts for these, note the word "scale" does not appear in the command. It appears in the "Other Edit" section of the Commands and the command names are simply 100%, 125%, etc.
Re: DP 10.13
MLI Kleanup Krew™ to isle 7.Phil O wrote:... until MOTU gets their poop in a group on this.
Isle 7, Kleanup Krew™...
Re: DP 10.13
Isle? Not aisle? Just how big is MLI?monkey man wrote: MLI Kleanup Krew™ to isle 7.
Re: DP 10.13
Gets bigger every day... the poo builds up, the island grows. Like Hawaii, but faster.bayswater wrote:Isle? Not aisle? Just how big is MLI?monkey man wrote: MLI Kleanup Krew™ to isle 7.
And smellier.
Re: DP 10.13
I must be getting old! I could have sworn there'd be a contraption or software in the MLI catalogue that should have automatically stepped in where Miss Pellings failed to show.
Naughty monkey! Take that!
Re: DP 10.13
Deleted - Wrong thread!
Re: DP 10.13
