Selecting tool in "Tool Pallette" problem
ellberge
Post by ellberge »
Using DP 10.11 on my Mac OS 10.13.6, I run into difficulties using the tools within the tool pallette window. Desiring to use the scissor tool I cannot activate it either by clickin on it or tapping C. Any solutions or suggestions would be welcome. Also true for most other tools.
FMiguelez
Re: Selecting tool in "Tool Pallette" problem
Post by FMiguelez »
Welcome to the forum.
What are those "difficulties" you speak of when selecting the tool from the palette?
You need to keep letter c pressed. Or double tap it, so it sticks.
If that doesn't work, see if you have a conflicting shortcut (via shift-L). That window is searchable, and it's a DP treasure cave.
waterstrum
Post by waterstrum »
FMiguelez wrote: You need to keep letter c pressed. Or double tap it, so it sticks.
Thanks for that!
I always press the key to use the tool intermittently.
Never knew about the double press for switching to the tool.
This will help me every day.
I suspect DP has thousands of other features that have eluded me.
So great to have the insight of all of the folks here.
All hail Motunation! :unicorn: :unicorn:
All is well
ellberge
Post by ellberge »
The problem was solved by quitting DP and then restarting. Why?
FMiguelez
Post by FMiguelez »
ellberge wrote:The problem was solved by quitting DP and then restarting. Why?
Restarting DP (and some times the computer) can solve A LOT of problems. Standard trouble-shooting stuff.
I have no idea why it is like that, though.
FMiguelez
Post by FMiguelez »
waterstrum wrote: Thanks for that!
My pleasure, WS :) Glad you found it useful.
