DP 10 & DP 9.52 together ???
GaryR
Post by GaryR »
DP 10 & DP 9.52 can they both coexist ??? Have been having some issues with DP 10
thank you so much I appreciate the help
Re: DP 10 & DP 9.52 together ???
Not on the same system drive. The last one installed overwrites the shared resources file. Many threads on this subject.
GaryR
Post by GaryR »
thanks so much Mike I have an older iMac i5 2014 so it's getting a bit sluggish can you point me to some of the threads ...i searched no luck. can DP 9 open Dp 10 files ??? thank you so much you are so helpful on this forum i see your posts when i visit a lot ...you're a good soul thanks g
DP9 cannot open DP10 files unless the DP10 file is saved as a DP9 file in DP10.
DP10 can usually open DP9 files, and almost always accept a DP9 file as via Load. I keep DP9 boot drive around just in case; have only had to use it once so far.
https://rbohemia.com
