Unidentified MIDI data!!!
- dhelpling
Hey you guys - since I upgraded to Catalina I have been seeing some strange MIDI data in a thin horizontal portion of the MIDI Editing Window. It gets recorded when I record MIDI parts, but appears to be random (isn't always there) and almost looks like HEX code. I have a screen capture image, but I'm not sure how to post it here. I would like to filter this data out or have it not generate the data at all. When zoomed out in the Track Editor I can't tell whether it is actually MIDI notes or not so it gets very misleading. Thanks much!
Re: Unidentified MIDI data!!!
Sounds like sysex data, David.
Unless you require it for bulk dumps to and from your gear, just disable it using the input filter in DP. Done.
- dhelpling
Thanks Monkey Man - I'll try that...
To be sure, open the track in the event list and filter out your basic data. Whatever is left over is your extra data.
