Freeze tracks not sample accurate in DP10.11
- Timeline
Does not zero out or add perfectly to original track. Is this plug related or an error DP?
- FMiguelez
Re: Freeze tracks not sample accurate in DP10.11
DP is full of little quirks like this, where too many things are far from being accurate, let alone sample accurate.
A most annoying one, which I've been dealing with these past days constantly, is Shifting (Shift command) SBs, MIDI notes, etc. I'ts never accurate either and always require babysitting and double checking.
Heavy automation still is as bad and unreliable as it's always been (still not reading simple plugin bypass state reliably).
What's happening that is taking MOTU so damned long for a much needed update?
Based solely on results, it's almost as if they had a single part-time person programming the app!
DP10 is useless to me in its present state... I went back to 9.52 2 days after trying 10.
- Timeline
thanks
