suddenly, panning doesn't seem to work
phantom power
Post by phantom power »
I'm on 9.51
All of a sudden, my panning doesn't seem to work. This is on tracks that I've been working on for awhile. They definitely weren't like this before.
Ideas?
-AE
Re: suddenly, panning doesn't seem to work
Please give us a little more detail... Audio, MIDI, VI? what are you doing, hearing and seeing?
Help me (and everyone else) help you
CharlzS
Post by CharlzS »
Mono Folddown selected on the Master fader? Does your audio output device have a mono button?
We needs lots more info. For example, my stereo tracks record properly but which way I monitor from my interface when tracking affects if I'm monitoring in mono or stereo—sometimes, I don't have a choice in this.
phantom power
It's happening with every audio track in the project. When I rotate the pan knob, I'm not seeing anything out of the ordinary. The only difference in sound is that it gets a little quieter as I pan full left or right. Center detent is louder. No panning at all.
I tried monitoring with headphones from my interface (828mk3 Hybrid), from the monitor controller (m-patch2), and straight out of the macbook pro. All of these had the same effect.
I did check the master fader for mono folddown (I never even really noticed that was there), and "none" is selected.
I've checked a few different projects, and this is the only one that's doing it.
phantom power
All were recorded to mono tracks. A couple have stereo inserts that have effectively turned them into stereo tracks. The problem occurs on both.
Is there a plug on the master with a mono out setting?
phantom power
So, it seems it was something with the Waves API2500 and an aux track. Thanks for the help.
phantom power wrote:So, it seems it was something with the Waves API2500 and an aux track. Thanks for the help.
I love a happy ending.
cuttime wrote: Sun Jun 28, 2020 1:22 pm Is there a plug on the master with a mono out setting?
Thanks. That saved my butt today.
ronjams
Post by ronjams »
Plenty of times I’ve felt that way and usually, I end up making the file mono if I can’t get the pan balance, right but I do understand I don’t have an explanation for that quirkiness that does happen in digital performer
Mac Studio M1 Max DIGITAL PERFORMER1248/8pre ESFalcon/kontakt/Unify & A LOT MORE GEAR
MIDI Life Crisis wrote: Sat Feb 11, 2023 4:25 pm
Kotter??
Tidwells@aol.com
Post by Tidwells@aol.com »
Welcome back, MLC/Kotter! I was afraid you might be deceased. Good to hear from you!
Doug
Good to see you MLC!
HC Markus
https://rbohemia.com
Tonio
Post by Tonio »
MLC ??? Where you been . You've been ghostin' us for so long , I hardly post anymore... :shake:
T
Mac Studio MAX 2TB/ 64GB RAM / DP11.2 / 828ES//
MP 5.1 3.33- 3 duo / OS10.14.6 / RX580 /DP10.13/828ES
