un-intelligent snapping??
elfspell
Post by elfspell »
hello good people!
Could you be so kind telling me how could I put this "artificial intelligence" snapping thing to rest for a bit before snaping myself? :deadhorse:
https://ibb.co/fxP75F4
pencilina
Re: un-intelligent snapping??
Post by pencilina »
I think this crossed by path at some point as well.
Maybe try messing with preferences>continuous data>set event density for ramps.
What is snapping? In the tracks overview window I believe all you can do it hit the CMD key to bypass that. In other windows, unblock the little black box above the window (or hit the cmd key) to defeat it. If you want to return to snapping after unchecking that box, hit the cmd key first and drag.
The Command(Mac) Ctl (Win) key lets you override Snap to Grid and Snap to Beat while being held.
Chaper 37 in the user guide gives you the complete picture and your many, many options including how to turn it off.
elfspell
Post by elfspell »
pencilina wrote:I think this crossed by path at some point as well.
Spot on my friend!!
Maximized the ticks and got a lot better!
pencilina
Post by pencilina »
Excellent! This was an option they introduced at some point with a senseless default.
This is like Boxing Day with the in-laws. Five conversations going on at once, all unconnected with the other four.
elfspell
Post by elfspell »
Ok... here we go again
how can I turn this thing off !!
https://s7.gifyu.com/images/2020-07-23_18-48-58.gif
When I fiddle with the volumes for soundbites it works ok.
For MIDI on the other hand it adds extra nodes.
pencilina wrote to mess with the "continuous data"..
apparently it did not do any good
please help...
pencilina
Post by pencilina »
Are any of your snapping settings on (which you can also invert by holding command as you drag)?
Is your event density set less then 50 ticks?
elfspell
Post by elfspell »
pencilina wrote:Are any of your snapping settings on (which you can also invert by holding command as you drag)?
All snapping settings are off and the ticks set to max (60)
The issue is not where the node snaps. But the extra dot that creates. I do not see that when I change the volume on a wave track (soundbite). It happens only to the MIDI.
pencilina
Post by pencilina »
Maybe set ticks to 10- they should be set at the minimum not maximum. It's weird. I've never seen that.
You might need to call motu.
