Until DP10, I was able to press the number 3 on my Mac keyboard to begin recording. It doesn't seem to work anymore? Is there a corresponding number I can press to simply begin recording?
Thank you! I couldn't find the answer via the manual.....
Best,
Sylvia
Number key for record?
Re: Number key for record?
Should still be number 3 (on the extended keyboard).. mine seems to work just fine. You might have to go into commands, transport section, to see if anything has changed.
Correct weight IMHO, mate.Killahurts wrote:You might have to go into commands, transport section, to see if anything has changed.
The numeric key was probably inadvertently assigned to another function, or de-assigned.
We assume OP has a keyboard with a numeric keypad?
