recording output of PC88 and MIDI tracks
pacover
Post by pacover »
I'm using DP 10 with a PC88 keyboard synth and Firewire Ultralite interface that is connected to an external speaker. I'm at the place where I like what I hear from the PC88 and MIDI tracks but need to make an audio recording of it. Is that possible in DP 10, or do I need to use an external audio recorder connected to the interface?
Re: recording output of PC88 and MIDI tracks
I believe you can "freeze" and bounce the track as usual. It will go into realtime, however. Have you tried that?
pacover wrote:I'm using DP 10 with a PC88 keyboard synth and Firewire Ultralite interface that is connected to an external speaker. I'm at the place where I like what I hear from the PC88 and MIDI tracks but need to make an audio recording of it. Is that possible in DP 10, or do I need to use an external audio recorder connected to the interface?
This is one of the basic functions of DP and your interface. Route the Ultralight audio inputs (to which your PC88 output is connected) to a record-enabled Stereo Audio Track in DP, then play the PC88 MIDI track while recording the its audio output in DP. You might want to review the DP Getting Started Guide.
pacover
Post by pacover »
Thank you so much HKMarkus!...I wasn't seeing the forest for the trees...it's your willingness to help which to you is a BASIC idea was a huge problem for me...and I really appreciate that you jumped in to help. Be well. Peter
