DP 4.6 and Tascams FW1082
Does anyone know if DP 4.x will play nicely with the Tascam FW1082 ? and is the Tascam FW1082 any good ?
Opinions ??
Thanks all
Tera
Opinions ??
Thanks all
Tera
Powerbook G4 1Ghz, 768M Ram, GEM RPG800. For vocal lesson recording: Behringer MXB1002 mixer, 2 x Behringer ECM 8000 omni mics, 2 x Behringer C2 cardiod mics, Edirol R-1. For recital recording: Alesis FireWire Multimix 16, 2 x Studio Projects C3 and an AT835b for vocal focus.
Just started using the Tascam 1082 with DP 4.6 on a G5 dual 2, as one of the workstations in my (I'm the teacher!) Music Tec facility at college; attached to a couple of Tannoy Reveal 6's, the set-up is abiolutely great. Control surface functions with no problems, audio is sweet as honey - even the MIDI interface (to a Triton) is 100% happy. Very highly reccommended.
Colin Orr
http://www.janus-music.com
Colin Orr
Re: DP 4.6 and Tascams FW1082
I hate 4.6 but love 4.52 because of the stupid CPU spikes I seem to get on any of my machines with any of my interfacesGibble wrote:Does anyone know if DP 4.x will play nicely with the Tascam FW1082 ? and is the Tascam FW1082 any good ?
Opinions ??
Thanks all
Tera
Just to preemt my comeents
I love my tascam it works well with DP 4.xx and the control surface has a special file to run with DP so thats even better
It is easy to use and has not missed a beat and is alot more flexable and uses way less cpu than my mlan card i use to use.
what else can i rell you ?
DP 4.52, Imac 2 GHZ G5 1 gig Ram
Powerbook 1.5ghz 1 gig RAM
Motif ES7 and Tascam FW1082 interface
I've never used the FW-1082, but I've been using the FW-1884 for a while now. First with a powerbook, and now with a tower. I can recomend it without hesitation.
I was using a 002 pro tools rig for a few years (since they first came out). I sold it a few months ago and bought the tascam and DP and couldn't be happier with that choice....it's so flexible.
only complaint....no scribble strips!!!!! what were they thinking?
Great replies !!
Thankyou to all who responded to my question. It looks like the FW1082 is well liked by those who use it, and it appears to have the feature set that I want, so, I'm off to order mine !!
Once again
Tera
Once again
Tera
Tera[/quote]
what else can i rell you ?[/quote]
what special file is this? I got a fw 1884 -
just getting back into Dp after years of PT
Do you use mackie control or HUI emulation?
In PT very easy to flip to auxes for stuff like reverb sends...
pouring over manual now...
have managed by pressing something to get flip to aux 4 ( can't flip to to 1-3) which appears to control aux 1. As for the rest....
my problem with the FW-1884 is that you have to be listening to the same mix as the player/singer. You can only have direct input monitoring on ONE mix. I can't find any way around this, and it is quite a limitation. So much so that I'm dumping my FW-1884.
If anyone knows a way around this, let me know.
Thanks,
j
Thanks,
j
try set player's mix from aux's?
ie every channel has an aux send set to a stereo bus. ( recommend prefader in this instance)
then route that us to an aux input
route aux out to a physical output ( ie different ones to your monitor - presume you have an amp for their heaphones/mons )
that should do it.
that should do it.
Yeah, but if you do it that way, there's latency equal to the buffer, right? When I do it that way, there's an annoying delay (latency) that really makes it impossible for a singer/player. Have you tried this set up?
Are you saying that you set up this aux mix in DP? I'm sure that's what you're saying, but maybe there's some other way you're saying to do it.
Thanks,
j
Thanks,
j
