I have Live Lite installed. It seems to come free with just about anything I buy. I'd like to leave it installed. But the Instrument tab in the DP Bundles window shows 38 channels of Abelton Live as the first VI. Looks like Live is publishing its outputs and DP is possibly misinterpreting them as VI outputs.
I think I've seen this before, and a way to get rid of it. IIRC, it was a Live setting. Can anyone remind me?
Live in DP Instruments Bundles
Re: Live in DP Instruments Bundles
I think those are ReWire bundles, and Ableton is not the only DAW that publishes these unwanted tentacles. Find them here:
https://help.ableton.com/hc/en-us/artic ... set-Rewire
Shut it off completely:
https://help.ableton.com/hc/en-us/articles/209772865
This apparently only works with Ableton. Not sure how to shut it off with other DAWS.
It didn't work. When I found the folders described in the second article, I saw that I had already done this for a previous version of Live. It did work on the earlier version, but not on 10.1 which appears to be the version I have. The article says the Options.txt file is not supported and may not work in future updates.
Perhaps there is a system level way to remove Rewire altogether, although I can't find one in a search. If not, I'll just have to ditch Live.
