Hi
I have a fresh Tiger instal and I've installed only the lastest version of mach 5 - 1.2.3. However I can't find the UVi program.
I've looked at a custom install from the original disk but I can't see an option for intalling the UVI program.
Any ideas?
Kim
How to get UVi extract back?
DID you check:
Mac HD> Application Support> Motu> Machive> UviX OSX
there it should be...
hope this helps.
hope this helps.
DP 10.13 , MACPRO Trashcan 2013 MACOS MOJAVE 10.4.6, Motu828X, MacBook Pro 2.1.6, MacPro, Machfive 3, Sampletank 4, Plugssound Pro,Yamaha MU128, Digitech GSP1101, MIDI Express 128, Studiophile BX8, Uviworkstation, Roland A33.OSX Motu Symphonic Instrument,Uvi Workstation. Kemper profiler Stage
Thanks for the reply Patricio. Yeah I did check that and there is no folder to speak of. I know where you are coming from because it used to be there in the old instal of Panther. I think I'm gonna have to reinstall the whole thing from the install CD and then install the update to 1.2.3 and see if that works.Patricio wrote:DID you check:
Cheers
Kim
