Bounce issue
dazzjazz
Bounce issue
Post by dazzjazz »
Hi all,
I'm having a weird audio glitch in bounced files that doesn't exist in the source multitrack.
I thought it was a poor fade that I subsequently repaired, but I've exported an MP3 again and the issue is still there - sounds like a record skipping a tiny bit.
Any thoughts on how to rectify this please?
Darren
iMac 27" 2013 24 GB RAM
OSX Catalina. Focusrite Clarett 8Pre. Heritage Audio HA73.
DP10.
Yamaha CP4. 1961 Hammond A100. Too many Leslies.
Darren Heinrich
BMus (Hons) Jazz Piano
PhD Jazz Organ Improvisation
http://www.dazzjazz.com/
Re: Bounce issue
BTD and converting to mp3 in one pass takes a fair amount of resources and time. For that reason, I never do it. I find it much faster to make it a 2-step process—much, much faster.
Try a bounce to whatever format and rate your files are. Now convert that to mp3 in iTunes.
Do you hear the same glitch?
If yes, it’s not the mp3 conversion. If no, the glitch is gone, there are many possible causes.
Re: Bounce issue
I'm thinking the same thing. Too many variables to be able to answer.
How many VIs? Tracks? Any "big" VIs sharing the same fader? That'll screw things up a bit, as will heavily scripted VI instruments.
Solutions abound but not w/o more info on the content.
Timeline
Re: Bounce issue
Post by Timeline »
VI's still don't properly convert correctly if complicated multiple VI's exist regardless of audio format.
I'm mainly working with NI Complete 11.
mesayre
Re: Bounce issue
Post by mesayre »
Are you using MIDI to control parameters in either Reaktor or Guitar Rig? I've seen some weird stuff where that causes bumps in automation on bounce that don't exist in realtime playback. I used to freeze the tracks using those specific plugs to be safe.
I
DP 10 - Win 10 - Ultralite AVB
Timeline
Re: Bounce issue
Post by Timeline »
mesayre wrote:Are you using MIDI to control parameters in either Reaktor or Guitar Rig? I've seen some weird stuff where that causes bumps in automation on bounce that don't exist in realtime playback. I used to freeze the tracks using those specific plugs to be safe.
I
No
Freezing always allows it to work yes.
I prefer the sound tone when allowing the VI to work live through bounce.
Re: Bounce issue
We still haven't heard back from the OP.
Timeline
Re: Bounce issue
Post by Timeline »
Still no update past .01. Not buying DP still.
