Multiple layers of markers
eoinrussell
Post by eoinrussell »
I use markers for scoring placement - 'hit this exciting moment' etc. But I want another layer of markers (or just labels I can see during playback) for section labels, or chords or similar, without losing my original scoring placement data.
How are people accomplishing this?
mesayre
Re: Multiple layers of markers
Post by mesayre »
No way to do layers that I'm aware of.
I use a prefix in the marker name, then use the search field in the markers window to look at only the ones I want to see.
For instance, anything I want to adjust/fix will be prefixed with "TODO:...", so I can just search for that and quickly jump to each spot. That can get as granular as you want. You could have sections start with "S-..." or mix-specific notes start with "MX...". You get the idea.
Low-tech, I suppose, but infinitely flexible.
DP 10 - Win 10 - Ultralite AVB
I was curious if Markers were "stored" in the conductor track, and whether using a 2nd Take in the Conductor would permit multiple sets of Markers, but such was not the case.
It would be cool if there was a MARKER TRACK, and that multiple takes or even multiple tracks could be created to show/hide various markers for different purposes.
dix
Post by dix »
I have, in the past, inserted notes on an unassigned MIDI instrument track as a rudimentary Marker track. Primitive, but it can work in some situations and can, of course, have multiple takes.
dix wrote:I have, in the past, inserted notes on an unassigned MIDI instrument track as a rudimentary Marker track. Primitive, but it can work in some situations and can, of course, have multiple takes.
Or use silent Sound Bites in a track folder at minimum height. You can name the tracks or the soundbites as you might a marker, or colour code them. Far from ideal but works sometimes to give quick visual clues.
While we're at it, I'd like to be able to edit the length of a marker as well as layer them.
labman
Post by labman »
bayswater wrote:While we're at it, I'd like to be able to edit the length of a marker as well as layer them.
That would be WAYYYYY cool Bays!
JSmith1234567
Post by JSmith1234567 »
I would love to have that!
I use markers for streamers when conducting, but can't use them to locate because there are a ton of streamers, and I wouldn't be able to find locate points among them.
I would absolutely get so much use out of being able to locate via markers.
I envy people who use Protools and can have something like this;
https://www.pro-tools-expert.com/home-p ... provements
OSX Big Sur (latest). Mac Pro Late 2013 ("trash-can"), 3.5 Ghz 6-Core Intel XeonE5, 64GB RAM. Motu DP 11.31, Vienna Pro Server, Presonus Notion, Osculator, Keyboard Maestro, Tanqueray or Bombay Sapphire.
JSmith1234567
I also wish you could have names in the soundbites as they appear, like the name of the track / instrument.
And the ProTools example shows the conductor track with tempos, and the markers tracks with names.
Bot of those would be immensely helpful.
darrell
Post by darrell »
If you're talking about more than one marker (as text or whatever) at a certain spot in the score, make markers using the same location in the markers window. It will 'stack' them one after the other so all are in view.
JSmith1234567
It's more I use markers/streamers for conducting and cues, but there are ton of those in a score, and once you are mixing, and would like to use markers for locate-points, you can't really do that because you end up with a zillion markers between the streamers and the locate-points.
Maxxy
Post by Maxxy »
mesayre wrote:stubbsonic » Wed May 15, 2019 12:04 am
Yes please .... Marker Takes.... in the Conductor Track... or in another track as stubbsonic suggests.... whichever.... Marker Takes....like audio or MIDI Takes.... same behaviour ...New, Duplicate, Rename etc..... please
dix and Bayswaters' workaround ideas are cool ....thank you ...use a MIDI track unassigned or a silent audio soundbite as Markers that 'Take'
But proper Marker Takes is a big please here
Thanks a lot
Maxxy
Mac mini 2023 M2 Pro, 32g RAM, LG 32UD99 4k monitor on HDMI, OSX 13.6.1, DP 11.31, MOTU TB AVB 16A w/AVB Monitor 8 on ethernet cable, UAD Apollo x8, Netstor TB3 PCIe card expansion w/ UAD-2... 1 x Octo and 2 x Quad cards (not using much because I looove >), Softube Console 1 MkIII & Fader Control
