in 10.01
i've found this a few times:
1. select a soundbite
2. select Region>Insert Loop
3. change the endpoint
4. press "Enter"
the loop goes in, but with the old endpoint - i have to go to the event list to set the correct endpoint.
this dialog box now remembers my last setting for number of loops - i often use it for infinite loops for experimentation, and i used to have to always check the setting before hitting "Enter" or i'd always end up with a one-repeat loop. i like that new behavior. but not being able to set an endpoint correctly is a bug, i believe. anyone else?
thanks,
tony
set loop bug?
set loop bug?
27" iMac 4.0GHz (late 2015), 32G RAM, OSX 10.13.6, DP10.01, UAD Apollo Duo TB, MTPAV USB (also 2021 14" MBP M1 Pro, 32G RAM, Apollo Twin Duo TB)
Re: set loop bug?
submitted a tech link, they confirmed it's a bug and told me, "it's in the engineer's hands now..."
