DP 10 Glitchy MIDI Playback.Even after Input Quantization
vtpettis
Post by vtpettis »
After recording keyboard parts in loop mode with input quantization (16th notes) the playback is glitchy and the second time around is cuts out completely. Could anyonr tel me what would cause this.Even if I quantize afterward it plays back Glitchy.Driving me nuts! :?:
magicd
Re: DP 10 Glitchy MIDI Playback.Even after Input Quantizatio
Post by magicd »
Are you triggering a virtual instrument with the MIDI track? If so the problem could be with the VI.
Test with a simple instrument such as the stock MOTU Polysynth. Any change in symptoms?
If you get smoother playback with a simple VI that indicates a possible performance issue with the original VI.
What is the hardware driver buffer size? If you raise that to 512 or 1024 does that change playback symptoms?
If it's a sample based instrument, where are the samples stored?
Dave
You certainly haven't lost your deft touch, Davo.
Asking all the right questions, as is typical. :headbang:
vtpettis
Post by vtpettis »
I'm playing the Waves Electric 88 and it seems better in DP 10.1.Also Komplete 12.I'll check some more today.My Samples are on a G drive mobile SSD
