It doesnt create a folder over here Mike, it just dumps the DP app into the Applications folder. Or am I missing the point?mikehalloran wrote:That's exactly it.If I screw things up I just reinstall 8 then, is that about it? ...
Both will install as Digital Performer. Rename the 8 folder as Digital Performer 8.07. When you install 9, rename that folder as Digital Performer 9.52 (if that's the version you are using). The dot . is important in the file name, apparently, or the folder will be overwritten. Subsequent installs will be also named Digital Performer — go ahead and trash them after installing. Your Digital Performer 8.07 and Digital Performer 9.52 folders will remain. You can make alias shortcuts to both in the toolbar.
Again, the latest installer will overwrite shared resources in a different folder. So, if you have both 8 and 9 working properly, good for you. If not, you know what to do.
Because of a client I had using DP 7.24, I played that game with 9.02 and 7.24 (one wouldn't run 64 bit plugs while the other wouldn't run 32 bit only plugins). When I upgraded to High Sierra and 7.24 would no longer run, I cut that guy loose till he upgraded to DP 9.
Anyway, just as an update, I went ahead and did it over the weekend (before reading this) and, of course, it broke my Powercore PCI card in DP8, although Powercore was still available in DP9. What the heck? And this is the plug that I use all the time, which I couldnt afford to lose in DP8, because it runs with latency in DP9. So now I'm screwed everywhere.
Not knowing what's going on, I spend a couple of days pondering restoring select files from Time Machine, which I dont even know how to do, (didnt want to restore everything and lose new emails, new stuff on the desktop, etc.), and having a TechLink chat with Travis at DP (a very knowledgable chap, who also talked about the renaming thing, by the way), during the course of which he suggested that perhaps DP8 was running 64bit, and perhaps Powercore is 32. Ding! ding! ding! we have a winner!
Somehow, during the installation process, DP8 had "flipped" from 32 to 64. (I know it was running 32 before the installation since I've been using it with Powercore forever. Couldnt have been in 64 mode)
It's been running fine for so long I had forgotten all about this incompatibility till Travis brought it up. (Very knowledgable chap.) So I switched it back, and all is hunky dory again.
The point of all this foolishness, if anyone cares, was to test a Waves plug in DP9 to see if it could replace Powercore, at which point I could upgrade systems and move forward...a little bit, slowly, and with trepidation. Turns out the plug Waves sold me (after an online chat. Not my fault) isnt compatible with 10.9.5. So I spent about a week spinning my wheels and got absolutely no place. I'm back at square one. My head hurts.
I know, TMI, but once again I just felt like sharing. And thanks, gents for all the advice, and the heartwarming compassion.
