Yeah. MIDI pitch bend is np here. ...Is pitch bend info not playing back from DP, or are performances not being recorded?remmet wrote:Moon landings aside, I found another issue with DP 10, and like several others issues I've brought up, some seem only to apply to my system and some are shared. What I just discovered is that pitch bend value 0 (zero) seems not to be recognized. More fun!
R
DP10 - Multiple issues
Re: DP10 - Multiple issues
- remmet
Pitch bend appears to both record and play back -- except for pitch bend with a value of zero, i.e., the value that returns the patch back to its regular pitch (an important feature for most music production).Yeah. MIDI pitch bend is np here. ...Is pitch bend info not playing back from DP, or are performances not being recorded?
I'm confident that these issues will eventually - hopefully very soon - be fixed. But having used Performer since the mid-80s through DP of the present (ca. 35 years!), I can't recall an update ever having this many serious problems.
R
Mac mini 2018 3.2GHz i7; OS X 15.2; 64 GB RAM; DP 11.32; Apollo X6; Kontakt; Omnisphere II; Adagio Everything, Spitfire almost Everything, Berlin Winds and Brass, Xosphere 2, and endless other sample libraries, acoustic and electric guitars, and assorted other essentials that have helped make me the "almost break even guy" my accountant so admires.
- waterstrum
I've had even worse luck than you. Even in DP9, Oberhausen crashes the MOTU Audio System. I have yet to hear it. That said, I'm using DP9 every day and loving it.monkey man wrote:Just a heads-up that Brainworx's new Oberhausen synth has MIDI-learn issues in DP9 and PA tech support can't even find the plugin in DP10.
Anyone planning on buying it should wait for an update.
All is well
Hmm. I happen to be working in DP10 on a track with pitch bend and I'm not seeing this. Could your controller be messing things up? Does it happen on all tracks with pitch bend info? Even tracks that are not Record enabled?remmet wrote:Pitch bend appears to both record and play back -- except for pitch bend with a value of zero, i.e., the value that returns the patch back to its regular pitch (an important feature for most music production).Yeah. MIDI pitch bend is np here. ...Is pitch bend info not playing back from DP, or are performances not being recorded?I inserted a value of zero right on a note: no effect. I tried placing it just before the note, with playback starting even earlier: still no effect. The only thing that worked was to move the pitch bend wheel on my MIDI keyboard. And oddly, if I change the value from 0 to 1, it works, but knowing it's not exactly on pitch can ruin my day.
Bummer, mate.waterstrum wrote:I've had even worse luck than you. Even in DP9, Oberhausen crashes the MOTU Audio System. I have yet to hear it. That said, I'm using DP9 every day and loving it.monkey man wrote:Just a heads-up that Brainworx's new Oberhausen synth has MIDI-learn issues in DP9 and PA tech support can't even find the plugin in DP10.
I haven't bought or run it; I was simply passing on the info shared by a GearSlutz member.
Initial reports are that it's not that much better than Arturia's SEM clone. I'm not surprised, the Arturia SEM is one of my favorites of theirs.waterstrum wrote:I've had even worse luck than you. Even in DP9, Oberhausen crashes the MOTU Audio System. I have yet to hear it. That said, I'm using DP9 every day and loving it.monkey man wrote:Just a heads-up that Brainworx's new Oberhausen synth has MIDI-learn issues in DP9 and PA tech support can't even find the plugin in DP10.
Well, Skippy loves it, but then you'd expect that seeing as he and Laurent Vironnez (Airwave) each contributed 100 patches to the factory library.
Hi All,
Does anyone know what has happened to the 'ENA' column in the DP10 Tracks window?
Opening a DP9.5 project with disabled tracks... I can switch on STC/CSH but no sign of ENA?
Is ENA no longer necessary?
Of course, I can create a new track and copy all the automation over manually....
Cheers
Kennos
Cheers
Kennos
It's there. Maybe you have it turned off in the Tracks List preferences.kenmccormack wrote:Hi All,
Cheers
Kennos
