I can't find High Sierra. I need to install it.
- Henry Robinett
I have two MacPros 5,1 . 3.46. The 2nd MP is still on ancient Yosemite. I want to install FCP on it. I have VEP and intend to use it as my VI computer. I tried buying FCP but it won't install unless it's at least High Sierra. So I tried installing Mojave but Mojave won't install on Yosemite. And HS won't install on Yosemite. I can't find High Sierra at the App Store. Can anyone point me to High Sierra?
All the best,
Henry Robinett
2019 Mac Pro 16 core, 192 GB; 2 MacPro 5,1 Metric Halo ULN-8 3d (x6), ULN-2-3d, MIDI Express XT,
DP10.13, UAD2 Quad TB,Duo,solo, Fractal Ax Fx III, FM3, LF+12+, Altiverb 7, Pianoteq7, Falcon, Keyscape, Omnisphere, Kontakt 5, Superior Drummer 3, Slate Drums, Live 10, Battery4, Diva, Spitfire Chamber and Symphony Strings, Ivory 2, Spectrafoo, Millennia HV3-D, many mics, many guitars . . ..
Henry Robinett
Re: I can't find High Sierra. I need to install it.
This page is supposed to have links to the full installer. Not on my Mac at the moment but, if this doesn’ Pan out, I’ll remember how to use my ftp server to get it to you.
https://forums.macrumors.com/threads/wh ... 0.2155955/
- rentadrummer
I had this link, which seems to still be working:
https://itunes.apple.com/us/app/macos-h ... ls=1&mt=12
Ron
- Henry Robinett
Thank you! I'm just having problems. It might not be compatible. I have a 2009 MacPro I upgraded to 3.46 gz 5,1. But when I try to install High Sierra it says I need to upgraded the firmware. I try but it doesn't seem to do it. Then I just got a possibly fake notice from Apple saying there's a problem with my account. All purchases will be suspended until I fix it. CLICK this button. I'm too paranoid. LOL.
All the best,
Henry Robinett
Henry Robinett
- Henry Robinett
OK, well I don't get it. I have two MacPros. I was wrong. The one I'm typing on now, my MAIN one, is early 2009. The one I'm trying to install HS on is mid 2010, the year they say is fine. So I must be doing it wrong. I looked very careful at the instructions and am trying one more time.
When Mac shuts down I hold the startup button until I hear the long beep. Then it's supposed to take a little while. I'm supposed to see the progress bar, which I don't see. I think this is because I'm not using an apple monitor. I've waited in this mode for the Mac to cycle and restart up to almost 2 hours. Yikes. But it SHOULD install. Anyone have any advice for me? Is this normal?
All the best,
Henry Robinett
Henry Robinett
- Henry Robinett
I think I'm making progress. Ignore me for now. LOL.
All the best,
Henry Robinett
Henry Robinett
Henry
We’re you able to upgrade to high Sierra. I was having the same problem with the firmware.
DP 9.12, OS 10.11.6, mac pro 8 core, 24 gigs ram, Mach Five 3.2, MSI, Superior Drummer, Battery, Reason, Slate Drums, EW Gold
http://www.2ndstprod.com
http://www.dannysguitarshop.tv
- buzzsmith
I just went through this. Don"t hold me to it, but I think I had to install Sierra first and then High Sierra.
As far as I can go unless I install a Metal compatible video card that Mojave requires.
Hope it helps!
Buzzy
Hope it helps!
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
So, I’m still on El Captain. Does this mean I’ll never be able to upgrade because I missed Sierra/High Sierra?
Yeah, I think you need High sierra installed first before you can move up to Mojave. It does a firmware upgrade I guess that needs to be seen by Mojave.
2012 6 Core 5.1, MacPro , (32 gigs Ram) Monterey, Radeon 570, 2013 MacPro #1 12 Core, (64gigs ram) ,2013 MacPro #2, 8 Core .(64 gig ram), Monterey, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT , DP11 , PT 2024 , Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 12, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
Sierra is not an issue. The High Sierra 10.13.6 final installer performs the correct firmware update without it.Babz wrote:So, I’m still on El Captain. Does this mean I’ll never be able to upgrade because I missed Sierra/High Sierra?
This link works to download the full 10.13.6 installer. It asks if you want to translate and open in the App Store — click Yes to both.
https://itunes.apple.com/de/app/macos-h ... 4741?mt=12
I was in contact with the OP. He was able to download, upgrade his firmware and install High Sierra. OS 10.13.6 is needed for the current version of FCPx.
If you are using any eGPU including DisplayLink, you may be limited to OS 10.13.3. There is a kludge foe 13.4–6 if your Mac is new enough to support AirPlay. My 2010 is not but my wife's 2011 is. In any case, proceed with caution. Mojave restored DisplayLink support.
This is the first I’ve heard of this firmware update thing. I just did some googling and I don’t think it applies to my late 2012 Mac Mini. Seems to be a Mac Pro thing.
That is not correct. It applies to all Macs on installation of High Sierra. In fact, if you did it incrementally, most steps included another firmware update. I don’t remember how many of the steps required one.Babz wrote:This is the first I’ve heard of this firmware update thing. I just did some googling and I don’t think it applies to my late 2012 Mac Mini. Seems to be a Mac Pro thing.
Well, FWIW, according to this, it should be possible to upgrade from El Capitan to Mojave, skipping High Sierra.
https://www.imore.com/updating-macos-ultimate-guide
