MIDI Keyboard not working with virtual instruments
abwhittier
Post by abwhittier »
Hello all,
As a beginner, I have a stupid question to ask and appreciate the help. My MIDI keyboard (Novation Launchkey 49) is not working whenever I try to play/record a virtual, instrument. When I open up MIDI monitor and press a key it does show activity on channel 1, but it will not work with my VI. When I launch the VI as a stand a lone, it works, but not in DP. In the past it has worked and I'm wondering if I changed some setting that is causing it to not respond. I just can't figure out what that may be.
All help is appreciated!
Thank you!
Re: MIDI Keyboard not working with virtual instruments
You do have both an Instrument track with the VI and a MIDI track enabled with the VI as the output and record enabled?
abwhittier
Yes, I do. When I record enable the track, I cannot playback on my MIDI keyboard. It does work if I try MIDI keys.
Check your controller output channel.
Try Preferences>MIDI Solo & Patch Thru>Auto Channelize.
And don’t fail to check the settings (if any) in your controller (MIDI channel modes and settings).
abwhittier
Hi all,
Thanks for your helpful words. I still have not been successful with getting my Novation Launchkey 49 to work in DP 9.52. I tried checking the output on the Novation, but that seems ok.
All the connections between the board and my computer work because I can operate plug ins as a stand a lone, but for some reason in DP it is not responding even though in MIDI monitor I can see activity when I press a key.
Would you have any more suggestions?
Thank you very much!
Is it being seen correctly in Audio/MIDI Setup (Apple app)? Is it appearing as in INPUT in DP at all?
abwhittier
Yes, I do see it in my MIDI studio in the Mac Audio MIDI setup. When I test that, it works with no problems.
Snoize MIDI Monitor can be a life saver in cases like this:
https://www.snoize.com/MIDIMonitor/
abwhittier
Thank you, I downloaded MIDI monitor and that is showing my keyboard is sending out data and working correctly.
I still can't understand why DP is not allowing me to control any MIDI data even though it is showing in the DP MIDI monitor that it's getting a signal when I press a key.
The novation launchkey 49 and DP were working a couple of weeks ago, but something has happened to cause this issue.
I sent my problem out to MOTU, but if any one has suggestions, I'd appreciate the help.
Thank you!
abwhittier
I also noticed that when I pencil in MIDI data, there is no audio. I hear the audio at playback, but not when I pencil it in. Not sure if this problem is related to my controller issue, but I wanted to mention it.
abwhittier
Hi all,
I found out the problem... it was the input filters not being checked.
Thanks again for your help!
Thanks for letting us know.
