AAF and OMF export crash DP 10
BobK
Post by BobK »
AAF and OMF export both crash DP 10 right after I click "OK" in the OMF/AAF Export Options dialog. The only change I made to default settings was to include audio files in the export.
Restarted the computer. Tried another DP Project. Same result after 3-4 attempts.
The projects I tested are very simple: they contain audio only, about a dozen tracks, one Soundbite/WAV file per track, 96/24. No edits, fades, plugins, or automation.
Anybody having success with this?
Bob
DP 11.23
Metric Halo ULN-8 mk4
Re: AAF and OMF export crash DP 10
I tried AAF and it crashed. Do you have DP 9 and 10 on the same partition? I did this with DP 10, but it sent a DP 9 crash report to MOTU. All the same things happened with an OMF export.
Tried it all again with DP 9.5.2. No crash, but no export files either.
I wonder if this is a result of DP9-10 conflict?
dix
Post by dix »
Same here. I can Export AAFs with audio with DP9, but the same operation crashes DP10. Definitely needs a TechLink.
apanacci
Post by apanacci »
Never worked for me.The work around I discovered is open the OMF or AAF file in Audio Desk and save it as a DP file.
2012 6 Core 5.1, MacPro , (32 gigs Ram) Monterey, Radeon 570, 2013 MacPro #1 12 Core, (64gigs ram) ,2013 MacPro #2, 8 Core .(64 gig ram), Monterey, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT , DP11 , PT 2024 , Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 12, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
apanacci wrote:Never worked for me.The work around I discovered is open the OMF or AAF file in Audio Desk and save it as a DP file.
This is about an error when you export from DP 10.
BobK
Post by BobK »
AAF worked with DP 9.01. Thanks!
Will submit Tech Link when I have a minute - right now I need to get work done!
Bob
DP 11.23
labman
Post by labman »
yeah we should all submit tech tickets. Seems like we keep beta'ing more and more stuff! :banghead:
labman wrote:Seems like we keep beta'ing more and more stuff! :banghead:
I think we're doing regression testing. Most of these bugs are things that worked before, and should have been caught before 10 went out for beta testing.
BobK
Post by BobK »
Tech LInk submitted!
Bob
DP 11.23
dix
Post by dix »
I was about to crack that at least import and export behavior was now consistent, but it seems like importing AAFs is fine now btw. I'm not sure when that got fixed.
apanacci
Post by apanacci »
Hey guys, I tried an AAF Export out of DP10 to PT 12 and it worked.I will follow this thread to see if there are more complaints, thanks
Saxplayerz
Post by Saxplayerz »
Import aaf crashes every time. :cry:
Don T
Post by Don T »
Hello,
I have successfully imported OMF from Audition.
It's the ear, not the gear!
MacPro 2.66 gHz 12 core (dp 10.01) - Lynx Aurora16 - OS 10.12.6/WaveArts/TruePianos - Legend 32ch console - G16 Fostex
(2) MacPro 2.66 gHz 12 core (DP 9.5) OS 10.12 - 24 I/O - 2408 mk2 - Da7- (PT 12) - 8 trk MCI
MacPro 2.66 gHz 12 core - OSX 10.12 - Genesys Black - Lynx Aurora16 - waves - Oxford - McDSP - 16 trk Otari - analog sweetness
JSmith1234567
Post by JSmith1234567 »
This consistently happened in previous DP versions for me also.
OSX Big Sur (latest). Mac Pro Late 2013 ("trash-can"), 3.5 Ghz 6-Core Intel XeonE5, 64GB RAM. Motu DP 11.31, Vienna Pro Server, Presonus Notion, Osculator, Keyboard Maestro, Tanqueray or Bombay Sapphire.
bralston
Post by bralston »
this is reportedly fixed in the just released 10.0.1 update today.
Regards,
Brian Ralston
___________________________________
- MacPro 7,1 3.2 GHz 16-core Intel Xeon W, 384GB 2933MHz DDR4 RAM, OS 10.15.7, 2TB SSD OS drive, 6TB Samsung Pro EVOPlus SSDs via Sonnet 4x4 M.2 PCIe card, Graphics card: AMD Radeon Pro Vega II 32GB, UAD-2 Quad, DP 10.13, DP 11.0,
- 15" MacBook Pro 2.3GHz 8‑core 9th‑generation Intel Core i9 processor, Turbo Boost to 4.8GHz, 32GB 2400MHz DDR4 mem, Radeon Pro Vega 20 w/4GB HBM2 mem, 2TB SSD storage, OS 10.15.7, 2TB SSD, DP 10.13
