I've got around 30 chunks in a project, each consisting of narration and underscore. Is there a way to just select all of them, and do a bulk mixdown of each to separate audio files? Or, am I going to have to go through them one at a time?
Been searching, but haven't really found anything on this yet ...
Bulk Export Mixed chunks?
- Primary DAW OS: Windows
Re: Bulk Export Mixed chunks?
Probably not. This is, in part, because a BTD has to be based on the same output bundle. Even if they all had the same output, batch bouncing isn’t In DP’s bad ‘o tricks.
I got the bright idea of just dragging all the chunks into a song, bouncing the song to disk, them cutting the file apart.
Didn't work. I don't typically use chunks/songs, but I thought the mix/plugin settings and such in each chunk would play back exactly as playing the chunk by itself in the song. But, all tracks came in at full volume and all my carefully tweaked level automation and such were gone.
Propably a setting for that. Looking now ...
