Keyboard to Dp 9 transpose "problem" ?
Hi guys,
I am editing/recording my styles in DP9 but when I do a transpose from Pa4x, DP does not recognise it.
To make it more clear.....
I have a percussion kit that Congas are on C0,D0.E0
I use the transpose from Korg PA4x to bring the sound to the physical keyboard at C3,D3.E3 so I can play it.
When I hit record my DAW does not record the C0,D0.E0 but C3,D3.E3 instead.
I could transpose it AFTER but it is not the best option because if you are loop recording, lets say a drum pattern, you are always listening the wrong samples.....
You have to stop, find where are the right ones transpose them and continue....not the best option ....
thank you!!!
thank you!!!
I am a very happy DAD.
MacPro 3.33Ghz 6core-32g Ram-10T HDs-10.12.6-Dp-10.0.1.
Korg Kronos 2-Korg Pa4X-Ensonic TS 10-Korg T3-Yamaha Dx 7iiFD-Akai S3000xl-Roland JV 2080
Genelec 1031A with KRK 10S sub-Yamaha NS10m
ULN-2..Tubetech Lca2B-Avalon 737sp-HEDD 192-Lexicon PCM 90.
Soundcraft Sapphyre 28ch
Re: Keyboard to Dp 9 transpose "problem" ?
If I understand you correctly, it sounds to me like you need to use DP's Transpose MIDI plugin with DP's MIDI Patch Thru set to on and your KORG set to transmit MIDI only (local off). Manual page 578.
Mac Pro 'Nehalem' 2 x 2.66 Quad Core, 28GB, 10.11.6 || MacBook Pro 2.7 Intel Core i7 Retina, 16GB, 10.11.6 || MOTU 2408 Mk3, 828 Mk 2, MTP AV || DP 9.51 & 9.13, Mach 5 v3, MSI, Ethno2, MX4, VEPro6, all Spectrasonics, Kontakt ... and many of the other usual suspects.
http://www.thekeyboard.co.uk
I have tried MIDI plugin (although it does not solve the problem entirely)....I sounds right but it does not print correctly.
Also I hear the note of the key I press (C3) together with the note that the MIDI plugin(C5) is giving me.
Local is off on the keyboard.
Are you sure you have it set to Local Off? Definitely sounds like a parallel MIDI path going on there.Yiannis wrote:Also I hear the note of the key I press (C3) together with the note that the MIDI plugin(C5) is giving me. Local is off on the keyboard.
Is the keyboard transmitting on more than one channel perhaps...?
Yes double and triple check.....I do hear and see two notes in the editor.HCMarkus wrote:Are you sure you have it set to Local Off? Definitely sounds like a parallel MIDI path going on there.Yiannis wrote:Also I hear the note of the key I press (C3) together with the note that the MIDI plugin(C5) is giving me. Local is off on the keyboard.
Definitely sounds like your controller may be transmitting on multiple ports/channels.
Have you tried using MultiRecord in DP and selecting only one channel as input?
Thats what I am doing right now...davidh wrote:Definitely sounds like your controller may be transmitting on multiple ports/channels.
I will come back with an update but I think its not a Dp problem.....something has to be done in the Pa 4x.
