Mojave eGPU
Mojave eGPU
Here we go again... amazing new OS and HW developments
waxman
Re: Mojave eGPU
Yep. I’m jazzed.waxman wrote:Here we go again... amazing new OS and HW developments
Had a few conversations out here in Austin. No secrets were spilled but I’ve learned a lot and many of my suspicions are being confirmed.
Re: Mojave eGPU
14.3 Six-core MacBook Pro with 32GB RAM
https://mybroadband.co.za/news/hardware ... eport.html
Xcode dark theme
https://9to5mac.com/2018/06/02/leaked-m ... -xcode-10/
Xcode dark theme
waxman
Re: Mojave eGPU
One of the big announcements yesterday was that iOS apps will be able to be ported to Mac OS. This lit up the chat boards with the expected speculation from the usual suspects predicting unified releases, $50 metronome apps and other nonsense.
I had dinner with an iOS engineer last night who filled me in (he never tells me anything that hasn’t been made public, of course). In this case, Apple is releasing SDKs that let developers port iOS apps to Mac OS with very little to no work for the developer. Apple has been working on this a long time as you can imagine. The first such apps will be from Apple, of course as they’re already done.
There are many reasons why this can’t be applied in reverse, all having to do with the fact that iOS devices have only a tiny fraction of the processing power and RAM of any Mac OS device. It’s not unified code—it can’ be (yet?).
Bottom line for me, it will be nice to install some iOS apps that I like on my Mac if and/or when the developer ports them over. iStroboSoft from Peterson Tuners is an app comes to mind as one I’d like to see.
https://www.petersontuners.com/products/istrobosoft/
Re: Mojave eGPU
Has it been determined whether Mojave will run on the converted 5,1 MPs many of us are using?
Re: Mojave eGPU
I know Peterson has a Mac Storobotuner app. I use it on my Mac and I can set it to "listen" to any input on my MOTU interface.mikehalloran wrote:iStroboSoft from Peterson Tuners is an app comes to mind as one I’d like to see. https://www.petersontuners.com/products/istrobosoft/
Re: Mojave eGPU
If you have a gpu that supports Metal, you should be good. Time will deliver certainty. Hidix wrote:Has it been determined whether Mojave will run on the converted 5,1 MPs many of us are using?
Re: Mojave eGPU
I see. I'm trying to determine if my ATI Radeon 5770 is such a GPU. I'm not positive, but it appears it is not. Would simply installing a Metal compatible video card make my machine Mojave-ready? Does your PC-RX460 support Metal?
Re: Mojave eGPU
http://osxdaily.com/2018/06/05/ios-12-s ... ices-list/dix wrote:Has it been determined whether Mojave will run on the converted 5,1 MPs many of us are using?
Re: Mojave eGPU
The correct link: http://osxdaily.com/2018/06/05/macos-mo ... macs-list/
I saw the compatibility list, but it's unclear if it applies to moded MPs like mine - It's effectively a 2010, but I think I'd need a new graphics card.
Re: Mojave eGPU
If true, looks like my 2010 iMac will become obsolete.
Well. the beta will let me know soon enough.
On the plus side, my DiaplayLink issue will be moot. Anything I buy will support 2 additional monitors without the USB Monitor Box.
Re: Mojave eGPU
Looks like 4 macs here are left behind in addition to two that are already stranded. One newer MacBook might squeeze through.mikehalloran wrote:If true, looks like my 2010 iMac will become obsolete.
Presumably, the beta might work on older Macs while the final release doesn't? It looks like Retina is a pre-requisite, and if so, there could be a workaround.
Re: Mojave eGPU
Not all iMacs and MacBooks from mid 2012 are Tetona yet they are supported.
If older Macs like ours are truly abandoned, it will show up early in the Beta releases, perhaps from the beginning. I have an eSATA boot SSD to test these things.
Re: Mojave eGPU
I suppose we could get lucky and there will be a Terminal Command that tells the installer to ignore non-compatible GPUs. ...
Could happen, right? I don't think so either.
Don't mind me ... I was supposed to be home hours ago. Austin—San Francisco direct was cancelled. Stuck in LAX—they think we can board in an hour. Not pleased with Alaska Airlines at the moment.
Re: Mojave eGPU
It doesn't get much more desperate than that. Six hours in Toronto while Air Canada looks for plane that works.mikehalloran wrote:Don't mind me ... I was supposed to be home hours ago. Austin—San Francisco direct was cancelled. Stuck in LAX—they think we can board in an hour. Not pleased with Alaska Airlines at the moment.
