Windows error (32)
Windows error (32)
Has anyone found the reason for or a fix for the Windows error 32 (occurs when undoing an audio recording [Ctrl Z or from the menu])?
- Primary DAW OS: Windows
Re: Windows error (32)
I have seen this from time to time. What I've found is that if I get that, I can usually still undo the thing by opening the undo history.
Not sure of the cause, not sure of the (real) fix. Let us know if you discover anything.
DP 10 - Win 10 - Ultralite AVB
Don't know if this is right, but this page would suggest that this error code is caused by an access violation:
https://msdn.microsoft.com/en-us/librar ... s.85).aspx
My guess is that DP is trying to move a file you've recorded to the undo folder (or delete it) while another process is still accessing the audio. I would guess generating the analysis overview. Maybe mess with your background processing preferences and see if it goes away?
Can't get to the Microsoft page you're referring to.
- jonathanprice
Same problem here. I find it works sometimes if I've waited a few seconds after recording before hitting Ctrl-Z, but it's not consistent.
Yes..., it does work when you wait a bit, but it's still quite annoying!
Have you submitted a Tech Link? What does MOTU Support say?
