Melodyne on sale again
Although it is on the upgrades, it is easy to buy a lower priced version and then upgrade it to 4 Studio for a total overall savings. I did that when I first got into Melodyne and saved a few hundred dollars in the process.
https://shop.celemony.com/cgi-bin/WebOb ... 29.23.5.39
The above site is in British pounds. Sweetwater has those same prices in US$
https://www.sweetwater.com/store/search.php?s=melodyne
as does AudioDeluxe
https://www.audiodeluxe.com/taxonomy/te ... 2b6fab38f0
If all you need is pitch correction, DP is good and there are many others. Nothing else can do what 4 Studio does and if you need that functionality, nothing less will do.
Phil O
Melda free plugin (limited time offer)
Post by Phil O »
menright
Re: 2 Free Plug-ins from Plug-in Boutique
Post by menright »
Rick Cornish wrote:Plugin Boutique has taken the opportunity to thank people for opting-in to their email list by giving away two free plugins: Air Music Technology Hybrid 3 and SoundSpot Nebula.
All you have to do is opt-in to their mailing list.
I opted-in and downloaded these two plugins (which look great) but can't get DP to recognize either one. My iLok Manager sees Hybrid and claims it's activated. I installed both as AUs and I can see them in the Components folder.
Anyone else having this problem? Any suggested cures?
Mike E
MacBook Pro 17' 2.66 GHz Intel Core i7, 8 GB, DP9.1, MachFive3, Ethno2, Synthmaster, Waves, UVI, Ableton Live
Mike E
Have you tried restarting your machine? Seems to be de rigueur for plugs these days.
PSP EMT
From email: "For next 3 days only, we’re offering our virtual incarnation of the legendary EMT 244 and EMT 245 reverbs: PSP 2445 at almost 70% discount for $49 only!" Expires on the 23th
RROY
Post by RROY »
Mike E
I did get these 2 freebies working. I think a restart helped. Hybrid 3 would not pass AU validation, but I activated it anyway and seems to be working okay. Not bad for free.
kgdrum
The Legend is on sale
Post by kgdrum »
The Legend(Moog) by Synapse Audio is on sale(end of May) grab it quickly if you want it!
This is a really nice synth 40% off for $60
https://rekkerd.org/save-40-off-the-leg ... pse-audio/
:dance:
On sale for $10. Normally $49. Not sure how useful this will be but passing it along:
https://www.bozdigitallabs.com/product/mongoose/
Here's the description from their website. I've bolded the part that explains exactly what the plug does:
Here’s the deal: Having a nice wide stereo spread is great. It helps your mix sound more spacious and less cluttered. Instruments seem to fight less and everything just sounds more clear. But our brain reacts differently to a wide stereo spread in high frequencies than it does in low frequencies. Large stereo spread in high frequencies = good. Large stereo spread in low frequencies = not so good.
The problem exists because of the way our ears and brains are used to hearing sounds naturally. With low frequencies, we can’t really detect where a sound is coming from. It’s the high frequencies that lets us know where a sound is coming from.
This can lead to some major issues when mixing on monitors. You might have some low frequencies that are coming out of only one speaker, and you won’t be able to tell. Put on headphones, and it becomes immediately obvious that there is a problem. You can feel your head instinctively turn as your brain tries to figure out why the low end sounds so unnatural.
This is where Mongoose comes in. It takes all those wide low frequencies and puts them right in the middle where they belong. The result is a low end that translates better to headphones and 2.1 systems, and just provides a tighter, more natural sound overall.
This plugin really couldn’t be any easier to use than it is. Just set your crossover frequency, and everything below that is summed to mono. You can also fine tune how wide the stereo image is by adjusting the width knobs. This is the kind of plugin that should automatically be on every master bus.
FMiguelez
Post by FMiguelez »
Me too. I opted in as well in exchange for the 2 free plugins, but there's no way DP's AU testing passes the Hybrid 3. I re-installed, restarted, etc., to no avail.
Similar experience. I couldn't get these to the point of usability, and gave up on them.
terrybritton
Post by terrybritton »
I am surprised hearing that. Can Macs use the VST versions? Hybrid is one of my rock-solid go-to plugins with low CPU hit and a vast number of sounds here on the PC.
Terry
MOTU 828 mk3 hybrid
corbo-billy
Post by corbo-billy »
Yes, for some time supports Windows 7 and Mac OS X & VST format .
http://motu.com/newsitems/dp-8-06-is-now-shipping
FMiguelez
Post by FMiguelez »
bayswater wrote:
FMiguelez wrote:
menright wrote:Plugin Boutique has taken the opportunity to thank people for opting-in to their email list by giving away two free plugins: Air Music Technology Hybrid 3 and SoundSpot Nebula.
Curiously, BOTH plugins were read and accepted by both, Live 10 and VE Pro. Both loaded fine in them.
It was DP the only one who refuses to accept them in its scanning.
I can see the VST versions there, but that would mean I'd have to change my preferred format to VST instead of AU, and I don't want that :boohoo:
FMiguelez wrote:I can see the VST versions there, but that would mean I'd have to change my preferred format to VST instead of AU, and I don't want that :boohoo:
No you don't. Just leave the preferred format to AU, but check the VST version in the plugin list in Preferences. It will be available after it is scanned. You can have as many VSTs as you like. I don't even remember what the point of specifying a preferred plugin format was. Maybe if you have both formats, it presents only the preferred one when you load a plugin. Something like that. And you can't use both formats of a single plugin at the same time.
kgdrum
Post by kgdrum »
Bayswater is correct, my preferred format is VST but I use plenty of AU plugs as well. ;-)
