bayswater wrote:Did this start with a template? If so, maybe try a template created in 9.5.2.
Interesting idea. I'll try that. You mean I have to create a new template from scratch, not just copy an old one?
You got it man! And thanks for removing the trolls.James Steele wrote:TDH... I am sorry you are having problems. I wonder if some of it is your workflow? It seems maybe MOTU needs to optimize automation. As I recall, don't you snapshot EVERY parameter of your plug-ins? And when you automate a parameter you don't just add automation for that one parameter but you sort of "brute force" snapshot ALL parameters of the plug-in, including the parameters that don't change? And this is with most of the plugs in your projects? Not trying to argue with you (I even deleted a rather rude response from a user) but it has seemed to me that your workflow is atypical and places a very large burden on DP with very large amounts of automation data, including much redundant automation data of parameters that aren't changing.toodamnhip wrote:Downloaded and installed. Opened current large mix file, Dp would only stutter. Terrible audio playback. Did a safe boot restart which cleans things up, tried again, no go. Only audio stutter. Buffers already maxed at 1024 so I even tried 512, no go. To me, 9.52 is a no go. I have to get back to work and have no time to debug. I will watch to see if anyone here similar has issues. I’m back to 8.07 for mixing large files, and 9.51 for MIDI mute work.
I cannot rid my mixes of Waves, there’d be little left lol. Of course DPs proprietary plugs work better. That is meaningless in realty. It may give a clue when doing research, but to me, it would be a useless clue. What could I do about it but mix thereafter with DPs plugs only? Talk about handcuffing myself..lolMIDI Life Crisis wrote:No time to debug, so my suggestions are not going to be helpful, but I'd start by going to only SAFE plugins. Anytime I've had these kinds of issues in the past it has ALWAYS been fixed by eliminating all things WAVES. I see TDH has Waves 9. I would (at the least) disable that and see if it fixes things... when you have the time.
James Steele wrote:TDH... I am sorry you are having problems. I wonder if some of it is your workflow? It seems maybe MOTU needs to optimize automation. As I recall, don't you snapshot EVERY parameter of your plug-ins? And when you automate a parameter you don't just add automation for that one parameter but your sort of "brute force" snapshot ALL parameters of the plug-in, including the parameters that don't change? And this is with most of the plugs in your projects? Not trying to argue with you (I even deleted a rather rude response from a user) but it has seemed to me that your workflow is atypical and places a very large burden on DP with very large amounts of automation data, including much redundant automation data of parameters that aren't changing.toodamnhip wrote:Downloaded and installed. Opened current large mix file, Dp would only stutter. Terrible audio playback. Did a safe boot restart which cleans things up, tried again, no go. Only audio stutter. Buffers already maxed at 1024 so I even tried 512, no go. To me, 9.52 is a no go. I have to get back to work and have no time to debug. I will watch to see if anyone here similar has issues. I’m back to 8.07 for mixing large files, and 9.51 for MIDI mute work.
There are many many reasons I “lock a mix”, and they could best be described with video tutorials, which I again, don’t have time for. I cant get into all of them here, but, A couple things-FMiguelez wrote:The thing is that, last I checked (at least 3 years ago), there was no easy way to tell DP which parameters you want from a plugin snapshot.James Steele wrote:And when you automate a parameter you don't just add automation for that one parameter but you sort of "brute force" snapshot ALL parameters of the plug-in, including the parameters that don't change? And this is with most of the plugs in your projects?toodamnhip wrote:Downloaded and installed. Opened current large mix file, Dp would only stutter. Terrible audio playback. Did a safe boot restart which cleans things up, tried again, no go. Only audio stutter. Buffers already maxed at 1024 so I even tried 512, no go. To me, 9.52 is a no go. I have to get back to work and have no time to debug. I will watch to see if anyone here similar has issues. I’m back to 8.07 for mixing large files, and 9.51 for MIDI mute work.
IIRC, the option is there in theory, but in practice it didn't work. So if you want to quickly snapshot full sections of the mixes, i.e., chorus and verses, it's either an all-or-nothing affair. I work like that sometimes, and it's really awesome and quick, especially if you have lots of plugin automation anyway. I think TDH also does this to "lock" all the parameters, even if some are not automated.
I'd be interested in knowing TDH's reason to do that (the all-parameter-locking), just out of sheer curiosity.
Please note that automating by manually recording only the parameters that do change doesn't really work for a workflow like the one above. The cool thing about it is the speed with which the section-automation can be done, and doing it one by one would be un-workable.
I will check if this situation has changed when I get time. Perhaps there's some kind of trick to make DP let you choose groups of parameters as desired, but it had either, a bug, or it didn't really work as expected, if my memory serves me well.
Yes, I had the same issue on a large mix. It also screwed up my 9.5 version so I am mixing back on 8.07. I have successfully used 9.52 on a new song that has a lower cpu footprint, but the large mixed could no longer be handled after the “upgrade”.Bennie Sims wrote:DP 9.52 is having a case of stuttering audio for me! I’m going back to 9.51!!! Anyone else having such issues?
Well, bayswater, you may have actually solved my problem. I made a new template from scratch in 9.52, copying the layout of my previous default template, and saved it as a new default. Then I copied the MIDI data of a solo piano part that had previously stopped bouncing MIDI after about 30-45 seconds. I then bounced that in the new template project and, lo and behold, it bounced the MIDI piano part complete!kinnylandrum wrote:bayswater wrote:Did this start with a template? If so, maybe try a template created in 9.5.2.
This could be timely, as I've had a couple mysterious crashes in 9.52. I remember having trouble in a couple previous incarnations of DP (7 going to 8?) that was very similar, and just creating a new scratch template solved the problems and made things run more smoothly. Sometimes you can have a prior version (or location) of a plug referenced that trips the breaker, etc.kinnylandrum wrote:Well, bayswater, you may have actually solved my problem. I made a new template from scratch in 9.52, copying the layout of my previous default template, and saved it as a new default. Then I copied the MIDI data of a solo piano part that had previously stopped bouncing MIDI after about 30-45 seconds. I then bounced that in the new template project and, lo and behold, it bounced the MIDI piano part complete!kinnylandrum wrote:bayswater wrote:Did this start with a template? If so, maybe try a template created in 9.5.2.
Since this bouncing problem has been a little intermittent, though fairly consist with any single track MIDI bounce, I'll just have to see if it solves all previous problems going forward. But again, I thank you for pointing out what is probably a solution that was not at all obvious to me or anyone at MOTU.
Thanks,
Kinny Landrum
I wonder this would work in some instances, rather than recreating your template from scratch.Tobor wrote:This could be timely, as I've had a couple mysterious crashes in 9.52. I remember having trouble in a couple previous incarnations of DP (7 going to 8?) that was very similar, and just creating a new scratch template solved the problems and made things run more smoothly. Sometimes you can have a prior version (or location) of a plug referenced that trips the breaker, etc.
So thanks from me for the reminder as well!
I do recall having the "old" template issue in a previous update of DP (I don't remember which version). I think I tried your method and it didn't do the job. I had to re-create all my templates. However, I haven't had this issue with 9.52, so I can't advise with confidence on this update. Just a heads up.bayswater wrote:I wonder this would work in some instances, rather than recreating your template from scratch.
1. Open your old template, rather than an old project.
2. Save immediately as a new empty project.
3. Quit.
4. Start up again, load the project in Step 2 and save as a template.
