Surround encoding
Surround encoding
Question 1:
What encoding options are available nowadays for encoding surround material in DP?
Is for a short to be shown at a movie theater.
Question 2:
If I bounce a 5.1 project using stereo, is it just bouncing L&R or is it bouncing a fold down?
The stereo is intended for the client to show the it around (in his computer probably)
Thank you!
Question 2:
Thank you!
Re: Surround encoding
In terms of channels, DP9 provides up to 10.1 AFAIK. The fold down option is electable for mono or stereo (if that was what you mean). I haven't done a surround mix in 10 years, so hopefully others will chime in and tell me where I'm wrong. They usually do... LOL
Re 1, I'm not sure what you mean by encoding. It used to be that encoded formats were more common, such as Dolby E and Lt Rt. Nowadays discrete 5.1 files are the norm for film. DP can export interleaved and deinterleaved in 5.1, 7.1 etc.
Re 2, Fold downs in DP include some of the surround, center and LFE information. Not just the L,R. Creating previews for clients is more or less what fold-down is for.
I did a test and the stereo bounce of a surround session is a foldown indeed.
About the encoder for cinema apparently is just sending the 6 audio files in a DCP package and all will be set as long as the channels are in SMPTE confg.
I suggest you look at Apple’s Compressor app for Mac as well. That can encode surround audio and lots of other stuff.
https://www.apple.com/final-cut-pro/compressor/
I’m not a full time film mixer, but that is my understanding and how I’ve delivered theatrical mixes. If they don’t specify, I’ll give them both discreet deinterleaved (.L, .R, .Ls, .Rs, .Lfe, .C) and interleaved to be safe....the interleaved may not be necessary.javierdh wrote:About the encoder for cinema apparently is just sending the 6 audio files in a DCP package and all will be set as long as the channels are in SMPTE confg.
Tested and confirmed:
Answer 1:
If you bounce a surround session using stereo, the file is a foldown.
Answer 2:
For cinema, just send the discreet files in the DCP, use SMPTE format. (unless you are dealing with a million dollar production who is willing to pay for the dolby ATOMOS
Thanks to all for your feedback!
J
Answer 1:
Answer 2:
J
