What happened to "run-in-real-time plug-in preference???
Re: What happened to "run-in-real-time plug-in preference???
These posts re What happened to "run-in-real-time plug-in preference??? are from 2016. Have there been any new developments? Has MOTU addressed this issue in any way. I am also having problems with not being able to control this parameter...
The only way to make sure they run in real time is to keep the plug-in's UI open and have the the plug-in set to run in realtime when open.Prime Mover wrote:Oh man, I'm still on DP8, but I wouldn't want to upgrade if I couldn't disable pre-gen. I have a few plugins, G-Force Mellotron in particular, that are all kinds of bad with pre-gen enabled.
Thanks for your post, James: The only way to make sure they run in real time is to keep the plug-in's UI open and have the the plug-in set to run in realtime when open.
Can please you explain how to do this? I use VEP with many VIs including Kontakt, GPlayer, and others...
