Tools (Scissor tool)
rockydill
Post by rockydill »
Scissor tool works fine when selected from Tools Window but not with C keystroke.
Can anyone explain this as I prefer the C option?
DP 9.51
FMiguelez
Re: Tools (Scissor tool)
Post by FMiguelez »
Simply hold and keep letter c pressed while you cut stuff around, or, double tap it, so it sticks and you free your hand.
All DP tools work like this 8)
rockydill
Post by rockydill »
Thanks for suggestion. But I am doing that and it's not working!
Some kind of glitch?
Sometimes a key is prioritized for use by the system. Your profile doesn't show whether you are Mac or Windows.
If Mac, you can go to Apple Menu/System Preferences/Keyboard/Shortcuts tab and look at the various categories and see if "C" by itself is used somewhere. I don't see it anywhere in the defaults. But perhaps something is using it?
FMiguelez
Post by FMiguelez »
After doing what Stubbsonic suggested, if it doesn't work, try changing the scissor tool to some other letter in DP's commands window (shift-L).
Also, try it with other tools to see if it works. Try letter z. The moment you press and hold it, it should turn into the zoom tool.
rockydill
Post by rockydill »
Thanks guys. I've allocated to a different keystroke and works fine now. (On Mac BTW)
