Howdy folks!
Anybody have any luck importing AAF files into DP 9.51?
If I click on the AAF file, DP opens but just stays there doing nothing.
If I try to open through DP, the AAF file is greyed out. Don't know why.
cheers
PS- AAF files come from Logic Pro 10.3.3
Importing AAF
- Tesionman
Importing AAF
Get Real Live Drum Tracks @ http://www.hugoribeiro.com
Macbook Pro | DP 10.13 | Motu 8Pre (x2) | Apogee Duet 2
Sonor Drums | Sabian Cymbals | Remo Drumheads | Vater Drumsticks
Re: Importing AAF
Good luck with that. Many problems with that. Many posts about that. How I get around it, is import it in Audio Desk and then save as a DP file and open that. See if that works for you.
2012 6 Core 5.1, MacPro , (32 gigs Ram) Monterey, Radeon 570, 2013 MacPro #1 12 Core, (64gigs ram) ,2013 MacPro #2, 8 Core .(64 gig ram), Monterey, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT , DP11 , PT 2024 , Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 12, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
- Tesionman
Re: Importing AAF
Changing the file extension from "AAF" to "aaf" worked.. its a weird solution but it worked.apanacci wrote:Good luck with that. Many problems with that. Many posts about that. How I get around it, is import it in Audio Desk and then save as a DP file and open that. See if that works for you.
cheers
Re: Importing AAF
Thats for info, worked a treat.
J
J
Re: Importing AAF
Glad it worked out
