Running into a strange issue that is hard to google...
I'm trying to automate a plugin using the 'insert' mode in the sequence editor.
What I'd like to do is for the track I'm effecting to simply play as normal for, say, the start of the song (and the plugin's detune knob is set to 50% which is12oclock on the knob where it has NO effect) to my chosen effect's start-point and then at this specific spot, have it detune for a couple beats (knob goes down to about 7 oclock) and then bump right back up to normal (12 oclock on the plugin's knob).
About the plugin's GUI:
If one were to simply open this plugin and look at its controls you'd notice that its knobs are set by default in the center position (12 oclock). In other words, when at this position (12 oclock) the knobs have no effect.
When I click 'insert' and then choose my plugin and finally select the specific parameter I want to automate ('detune' in my case), the pencil tool is selected and, apparently, I'm supposed to be able to draw in the automation that I want with this??
This seems very odd to me as the pencil allows me to set points but they're hardly exacting. In fact, I don't think anyone could use that pencil tool and click in the exact same spot twice in a row could they?
What if you wanted this exact (and I mean EXACT) automation to happen on another track? The pencil tool wouldn't work to match it!?
In fact, I haven't quite wrapped my head around what, exactly, I'm supposed to do with this tool...
If I'm in the sequence editor and want this automation to start at dead-nuts 50% of my waveform (as that's where the knob is set by default..i.e. no effect) and then go all the way to the bottom (I have the range of '-2' selected in the plugin's gui) so that the pitch only dives down 2 half steps, how can I start the effect with precision accuracy? In other words, how can I start it in its default position of 'no effect', move it all the way to the bottom, and then back up to the 'no effect' position? If I use the pencil tool it always selects near where it should but never dead-nuts in the middle.
Basically, if I make this choice visually and try to click right in the middle of my waveform, I'll never be able to find the exact 50% point to match the 50% setting (i.e. 12oclock) of my targetted parameters knob. Therefore, the automation will always start effected.
This is an odd problem and I'm having problems verbalizing it but I could keep trying. I can't believe what I'm talking about is that uncommon...
Has anyone dealt with this before?
Thanks for any advice!!
