Is it possible to use both the MIDI Timepiece AV (USB) and Micro Lite MIDI Interfaces concurrently? Studio One and SONAR only sees one or the other.
Thanks!!!
- Primary DAW OS: Windows
Re: MIDI Timepiece AV (USB) and Micro Lite MIDI Interface
If the firmware is 2.0.1 on the MTP, shouldn't be a problem—or rather it is't on a Mac. The Micro Lite is much newer so the firmware shouldn't be a problem.
Why your Win machine makes you chose one or the other, I don't know. How are you connecting them? Hub? Daisy chain? Multiple USB ports on your PC?
